[Qgis-user] GeoPackage deadlocks (Andrea Peri)
Luigi Pirelli
luipir at gmail.com
Fri Sep 27 00:59:21 PDT 2019
without resting importance to the issue, reading the bug report, I can read
you moved from oracle spatial to geopackage! why not postgis?
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition
<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
* Hire a team: http://www.qcooperative.net
On Fri, 27 Sep 2019 at 09:39, Paul Wittle <paul.wittle at dorsetcouncil.gov.uk>
wrote:
> Hi,
> I couldn’t see a bug report which I thought matched so I have added one as
> requests but please accept my apologies if it does turn out to be a
> duplicate or if my use of the word deadlock is incorrect.
> The ticket can be found at https://github.com/qgis/QGIS/issues/32034
> It would be great if others that have experienced the issue could provide
> any further relevant comments as I’ve not got it as well documented as I’d
> like. Sorry, time constraints in the office.
> Many thanks,
> Paul
> *From:* Alessandro Pasotti <apasotti at gmail.com>
> *Sent:* 27 September 2019 08:20
> *To:* Paul Wittle <P.Wittle at dorsetcc.gov.uk>
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] GeoPackage deadlocks (Andrea Peri)
> On Fri, Sep 27, 2019 at 9:13 AM Paul Wittle <
> paul.wittle at dorsetcouncil.gov.uk> wrote:
> Hi Andrea and Enrico,
> Thank you for providing an answer even if it was not what I was hoping to
> hear; it was the conclusion I'd reached myself.
> Has this issue been considered given the official move from shapefile to
> geopackage as the default format?
> My understanding was that shapefiles could be used over a network and
> whilst multiple people editing was dangerous it did not cause deadlocks.
> Combined with the issues relating to MapInfo tab files over a network I've
> got into some hot water over my attempt to get QGIS rolled out in our
> organisation now. I'm going to have to think carefully about my next steps
> as it can be difficult to educate large numbers of staff and the two issues
> mean that people using QGIS incorrectly can cause pretty big issues.
> To summarise,
> - You open a geopackage and save to the network; someone else comes along
> and opens it in their QGIS and everything looks okay until the PCs
> deadlock...ICT help calls and data corruption may occur.
> - You open a MapInfo tab file from the network and it looks fine (accept
> that it my draw in a user projection). MapInfo user receive errors but this
> is unknown to the QGIS user...ICT help calls result.
> Whilst I'm glad the forums have helped to diagnose both behaviours I would
> personally say that the issues pose a bit of a threat to software adoption
> by larger companies and institutions that may be using Windows networks and
> potentially migrating from MapInfo.
> In both cases my gut feel is that the best solution might be to look into
> use detection. If GDAL (I assume) can be improved to detect that either
> file type is already open then it might be possible to simply ban a second
> user from opening the file at the same time. This might frustrate some
> users but most importantly it would make the application safer from an ICT
> perspective.
> These are of course just my personal opinion from my particular use case
> so please don't be offended by them if you disagree but I'd be really happy
> to hear how others are approaching the issues and/or opposing views?
> Many thanks,
> Paul
> Hi Paul,
> A deadlock is a QGIS bug (and quite a serious one).
> Can you please file an issue on https://github.com/qgis/QGIS/issues ?
> Please check if it's not there, and if it is, you can add your comments to
> the existing issue.
> Thanks
> Alessandro Pasotti
> w3: www.itopen.it
> This e-mail and any files transmitted with it are intended solely for the
> use of the individual or entity to whom they are addressed. It may contain
> unclassified but sensitive or protectively marked material and should be
> handled accordingly. Unless you are the named addressee (or authorised to
> receive it for the addressee) you may not copy or use it, or disclose it to
> anyone else. If you have received this transmission in error please notify
> the sender immediately. All traffic may be subject to recording and/or
> monitoring in accordance with relevant legislation. Any views expressed in
> this message are those of the individual sender, except where the sender
> specifies and with authority, states them to be the views of Dorset
> Council. Dorset Council does not accept service of documents by fax or
> other electronic means. Virus checking: Whilst all reasonable steps have
> been taken to ensure that this electronic communication and its attachments
> whether encoded, encrypted or otherwise supplied are free from computer
> viruses, Dorset Council accepts no liability in respect of any loss, cost,
> damage or expense suffered as a result of accessing this message or any of
> its attachments. For information on how Dorset Council processes your
> information, please see www.dorsetcouncil.gov.uk/416433
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190927/65e18d02/attachment-0001.html>
