[Qgis-user] QGIS 3.4.12 python error on open plugins list manager
Borys Jurgiel
lists at borysjurgiel.pl
Fri Sep 27 04:49:30 PDT 2019
Btw. could you please confirm I'm right and you have Qt < 5.6?
Borys
Dnia piątek, 27 września 2019 13:32:09 CEST Walter Lorenzetti pisze:
> After uninstall purge of qgis and qgis.-server and reinstall I obtain
> same error :(
> I'm on Ubuntu 16.04,could be realted to it?
> W
> Il 27/09/19 12:56, Walter Lorenzetti ha scritto:
> > I try to clear QGIS3.ini file form custom settings and clear python
> > profile folder, but Now I otain this:
> > Si è verificato un errore durante l'esecuzione delle istruzioni
> > seguenti: pyplugin_installer.instance().showPluginManagerWhenReady()
> > Traceback (most recent call last): File "", line 1, in File
> > "/usr/share/qgis/python/pyplugin_installer/installer.py", line 252, in
> > self.fetchAvailablePlugins(reloadMode=False) File
> > "/usr/share/qgis/python/pyplugin_installer/installer.py", line 120, in
> > fetchAvailablePlugins repositories.requestFetching(key) File
> > "/usr/share/qgis/python/pyplugin_installer/installer_data.py", line
> > 325, in requestFetching
> > self.mRepositories[key]["QRequest"].setAttribute(QNetworkRequest.FollowRed
> > irectsAttribute, True) AttributeError: type object 'QNetworkRequest' has
> > no attribute 'FollowRedirectsAttribute'
> > Versione Python: 3.5.2 (default, Jul 10 2019, 11:58:48) [GCC 5.4.0
> > 20160609]
> > I tried to create a new profile but same error.
> > I'll try to reinstall qgis
> > W
> > Il 27/09/19 11:02, Borys Jurgiel ha scritto:
> >> The debug output doesn't want to help, indeed...
> >> Could you try to start a new fresh user profile? It would eliminate two
> >> possible causes: all the user settings (especially the QGIS3.ini file)
> >> and all user-installed Python stuff from
> >> ~/.local/share/QGIS/QGIS3/profiles/default/python
> >> Borys
> >> Dnia piątek, 27 września 2019 09:10:42 CEST Walter Lorenzetti pisze:
> >>> Hi Borys,
> >>> it's strange because Python Console working normally, also current
> >>> plugins installed.
> >>> I haven't many installed plugins, only DBManager and Quickmpaservices..
> >>> Running QGIS by shell, on bootstrap I obtain this:
> >>> Warning: void DBusMenuExporterPrivate::addAction(QAction*, int): Already
> >>> tracking action "Search QMS" under id 288
> >>> Warning: QVariantMap DBusMenuExporterDBus::getProperties(int, const
> >>> QStringList&) const: Condition failed: action
> >>> and on opening plugins manager window this:
> >>> "<font color=\"red\">Si è verificato un errore durante l'esecuzione
> >>> delle istruzioni
> >>> seguenti:<br><tt>pyplugin_installer.instance().showPluginManagerWhenRead
> >>> y()< /tt></font><br><pre><br>traceback.print_exception()
> >>> failed<br></pre>Versione Python:<br><br><br>Versione di
> >>> QGIS:<br>3.4.12-Madeira 'Madeira', 625767347a<br><br>Percorso
> >>> Python:<br>"
> >>> W
> >>> Il 26/09/19 19:59, Borys Jurgiel ha scritto:
> >>>> Not really, except something wrong happens in Python.
> >>>> The plugin manager window is C++ itself, however, when you click to
> >>>> open
> >>>> it, it calls that Python function from your first error message to
> >>>> fetch
> >>>> Python plugins from the repository. When the plugin list is ready,
> >>>> Python
> >>>> calls back the C++ API to open the window.
> >>>> Apparently something bad happens in Python when it tries to fetch new
> >>>> plugins. Are Python plugins generally work for you (hopefully you had
> >>>> some enabled, at least Processing or DB Manager)? Does the
> >>>> Plugins->Python console seem to work? Another idea is maybe running
> >>>> QGIS
> >>>> from the command line would give some debug messages.
> >>>> Borys
> >>>> Dnia czwartek, 26 września 2019 15:46:12 CEST Walter Lorenzetti pisze:
> >>>>> Hi list,
> >>>>> I'm on QGIS 3.4.12 on Ubuntu desktop, today on opening the list
> >>>>> plugins
> >>>>> window manager, I obtain the seguent error:
> >>>>> traceback.print_exception() failed
> >>>>> Any idea about it?
> >>>>> Thanks in adavance.
> >>>>> W
> >>>> _______________________________________________
> >>>> Qgis-user mailing list
> >>>> Qgis-user at lists.osgeo.org
> >>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Walter Lorenzetti phD email: lorenzetti at gis3w.it skype: aiki74
> > twitter:w_lorenzetti <https://twitter.com/w_lorenzetti> g+:aiki74
> > <https://plus.google.com/117055903318462447104/> Tel/Cell: (+39)
> > 347-6597931 Viale Verdi 24 - 51016 Montecatini Terme (PT) Nuovi corsi
> > QGIS e GFOSS <http://gis3w.it/it/calendario-corsi-software-geografici>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
