[Qgis-user] QGIS 3.4.12 python error on open plugins list manager
Walter Lorenzetti
lorenzetti at gis3w.it
Fri Sep 27 05:35:35 PDT 2019
Hi, ichoose the second solution and works!!
Thanks a lot Borys!!!
W
Il 27/09/19 13:41, Borys Jurgiel ha scritto:
> Hi,
> The bad news is you just discovered a regression in QGIS 3.4.11 - it's now
> unexpectedly dependent on Qt 5.6 (what is probably not available in your
> Ubuntu).
> The good news is there is a quick workaround. You can either rollback to
> 3.4.10 or edit your 3.4.11 to disable that improvement (probably insignificant
> for you, as it only concerns private repositories with redirections) and bring
> back compatibility with Qt < 5.6. Just edit the file:
> /usr/share/qgis/python/pyplugin_installer/installer_data.py
> and comment out line 325:
> # self.mRepositories[key]
> ["QRequest"].setAttribute(QNetworkRequest.FollowRedirectsAttribute, True)
> It should help now :)
> Regards,
> Borys
> Dnia piątek, 27 września 2019 12:56:18 CEST Walter Lorenzetti pisze:
>> I try to clear QGIS3.ini file form custom settings and clear python
>> profile folder, but Now I otain this:
>> Si è verificato un errore durante l'esecuzione delle istruzioni
>> seguenti: pyplugin_installer.instance().showPluginManagerWhenReady()
>> Traceback (most recent call last): File "", line 1, in File
>> "/usr/share/qgis/python/pyplugin_installer/installer.py", line 252, in
>> self.fetchAvailablePlugins(reloadMode=False) File
>> "/usr/share/qgis/python/pyplugin_installer/installer.py", line 120, in
>> fetchAvailablePlugins repositories.requestFetching(key) File
>> "/usr/share/qgis/python/pyplugin_installer/installer_data.py", line 325,
>> in requestFetching
>> self.mRepositories[key]["QRequest"].setAttribute(QNetworkRequest.FollowRedir
>> ectsAttribute, True) AttributeError: type object 'QNetworkRequest' has no
>> attribute 'FollowRedirectsAttribute'
>> Versione Python: 3.5.2 (default, Jul 10 2019, 11:58:48) [GCC 5.4.0 20160609]
>> I tried to create a new profile but same error.
>> I'll try to reinstall qgis
>> W
>> Il 27/09/19 11:02, Borys Jurgiel ha scritto:
>>> The debug output doesn't want to help, indeed...
>>> Could you try to start a new fresh user profile? It would eliminate two
>>> possible causes: all the user settings (especially the QGIS3.ini file) and
>>> all user-installed Python stuff from
>>> ~/.local/share/QGIS/QGIS3/profiles/default/python
>>> Borys
>>> Dnia piątek, 27 września 2019 09:10:42 CEST Walter Lorenzetti pisze:
>>>> Hi Borys,
>>>> it's strange because Python Console working normally, also current
>>>> plugins installed.
>>>> I haven't many installed plugins, only DBManager and Quickmpaservices..
>>>> Running QGIS by shell, on bootstrap I obtain this:
>>>> Warning: void DBusMenuExporterPrivate::addAction(QAction*, int): Already
>>>> tracking action "Search QMS" under id 288
>>>> Warning: QVariantMap DBusMenuExporterDBus::getProperties(int, const
>>>> QStringList&) const: Condition failed: action
>>>> and on opening plugins manager window this:
>>>> "<font color=\"red\">Si è verificato un errore durante l'esecuzione
>>>> delle istruzioni
>>>> seguenti:<br><tt>pyplugin_installer.instance().showPluginManagerWhenReady
>>>> ()< /tt></font><br><pre><br>traceback.print_exception()
>>>> failed<br></pre>Versione Python:<br><br><br>Versione di
>>>> QGIS:<br>3.4.12-Madeira 'Madeira', 625767347a<br><br>Percorso
>>>> Python:<br>"
>>>> W
>>>> Il 26/09/19 19:59, Borys Jurgiel ha scritto:
>>>>> Not really, except something wrong happens in Python.
>>>>> The plugin manager window is C++ itself, however, when you click to open
>>>>> it, it calls that Python function from your first error message to fetch
>>>>> Python plugins from the repository. When the plugin list is ready,
>>>>> Python
>>>>> calls back the C++ API to open the window.
>>>>> Apparently something bad happens in Python when it tries to fetch new
>>>>> plugins. Are Python plugins generally work for you (hopefully you had
>>>>> some enabled, at least Processing or DB Manager)? Does the
>>>>> Plugins->Python console seem to work? Another idea is maybe running QGIS
>>>>> from the command line would give some debug messages.
>>>>> Borys
>>>>> Dnia czwartek, 26 września 2019 15:46:12 CEST Walter Lorenzetti pisze:
>>>>>> Hi list,
>>>>>> I'm on QGIS 3.4.12 on Ubuntu desktop, today on opening the list plugins
>>>>>> window manager, I obtain the seguent error:
>>>>>> traceback.print_exception() failed
>>>>>> Any idea about it?
>>>>>> Thanks in adavance.
>>>>>> W
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Walter Lorenzetti phD
email: lorenzetti at gis3w.it
skype: aiki74
twitter:w_lorenzetti <https://twitter.com/w_lorenzetti>
g+:aiki74 <https://plus.google.com/117055903318462447104/>
Tel/Cell: (+39) 347-6597931
Viale Verdi 24 - 51016 Montecatini Terme (PT)
Nuovi corsi QGIS e GFOSS
<http://gis3w.it/it/calendario-corsi-software-geografici>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190927/6e9171c8/attachment.html>
