[Qgis-user] Install Quick Map Services Plugin in Ubuntu 18.04
J. M
jimimckay at gmail.com
Fri Sep 27 11:09:31 PDT 2019
Hi Matthias,
Thanks a lot! I figured that out from another tutorial shortly afterwards,
sorry! I didn't realise you could install plugins from within QGIS; I
assumed I had to download, install and dpkg them or something!
Cheers!
Jimi.
On Fri, Sep 27, 2019 at 8:01 PM Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Jimi,
> You need to install the plugin from within QGIS. No need to directly
> download it from anywhere yourself.
> See
> https://docs.qgis.org/3.4/en/docs/training_manual/qgis_plugins/fetching_plugins.html
> Does that help?
> Cheers
> Matthias
> On 9/27/19 7:54 PM, J. M wrote:
> Hi there,
> I was following a tutorial on QGIS.org (
> https://docs.qgis.org/3.4/en/docs/training_manual/qgis_plugins/plugin_examples.html
> and I can't get past step 2. I followed the link and downloaded QMS, but I
> can't for the life of me get it to install. I moved it from Downloads into
> usr/bin and then extracted it to create a folder. The 'readme' files might
> as well be written in Mandarin (of which I'm not a speaker..).
> Could anyone please help me with how to install the plugin?
> Cheers,
> Jimi.
> 10.2.1. [image: basic] Follow Along: The QuickMapServices Plugin
> The QuickMapServices plugin is a simple and easy to use plugin that adds
> base maps to your QGIS project. It has many different options and settings,
> let’s start to explore some of its features.
> 1.
> Start a new map and add the roads layer from the training_data
> Geopackage.
> 2.
> Install the *QuickMapServices* plugin.
> 3.
> Open the plugin’s search tab by clicking on Web ‣ QuickMapServices ‣
> Search QMS. This option of the plugin allows you to filter the
> available base maps by the current extent of the map canvas.
> 4.
> Click on the Filter by extent and you should see one service available.
> 5.
> Click on the Add button next to the map to load it.
> 6.
> The base map will be loaded and you will have a satellite background
> for the map.
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190927/3407ffb9/attachment.html>
