[Qgis-user] Install Quick Map Services Plugin in Ubuntu 18.04
Matthias Kuhn matthias at opengis.ch
Fri Sep 27 11:01:17 PDT 2019
Hi Jimi,
You need to install the plugin from within QGIS. No need to directly
download it from anywhere yourself.
See
https://docs.qgis.org/3.4/en/docs/training_manual/qgis_plugins/fetching_plugins.html
Does that help?
Cheers
Matthias
On 9/27/19 7:54 PM, J. M wrote:
> Hi there,
> I was following a tutorial on QGIS.org
> (https://docs.qgis.org/3.4/en/docs/training_manual/qgis_plugins/plugin_examples.html)
> and I can't get past step 2. I followed the link and downloaded QMS,
> but I can't for the life of me get it to install. I moved it from
> Downloads into usr/bin and then extracted it to create a folder. The
> 'readme' files might as well be written in Mandarin (of which I'm not
> a speaker..).
> Could anyone please help me with how to install the plugin?
> Cheers,
> Jimi.
>     10.2.1. basic Follow Along: The QuickMapServices Plugin
> The QuickMapServices plugin is a simple and easy to use plugin that
> adds base maps to your QGIS project. It has many different options and
> settings, let’s start to explore some of its features.
> 1.
>     Start a new map and add the roads layer from the
>     |training_data| Geopackage.
> 2.
>     Install the *QuickMapServices* plugin.
> 3.
>     Open the plugin’s search tab by clicking on Web ‣ QuickMapServices
>     ‣ Search QMS. This option of the plugin allows you to filter the
>     available base maps by the current extent of the map canvas.
> 4.
>     Click on the Filter by extent and you should see one service
>     available.
> 5.
>     Click on the Add button next to the map to load it.
> 6.
>     The base map will be loaded and you will have a satellite
>     background for the map.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190927/f0dcde37/attachment-0001.html>
