[Qgis-user] use color codes, save a style
Renato Saboya
rtsaboya at gmail.com
Fri Sep 27 15:05:56 PDT 2019
Perhaps you should use the long term release (QGIS 3.4.x), since it is the
most stable version and therefore should give you less headaches with
crashes and bugs.
1. First, let's tackle the most obvious: Is it a categorized or simple
symbol map? If it is a simple map, isn't the state selected? If it is
categorized, isn't this state different than the others by the mapped
attribute? It's probably none of this options, but I thought they were
worth the try.
2. When you say "same geometry" I don't know if you mean the same shapefile
/ layer or you just mean that both are polygon, line or point layers.If it
is the latter, usually this happens when we apply the style to a similar
layer that doesn't have the exact same column name used to symbolize the
original one. QGIS searches for that column name and, not finding it,
returns nothing.
Best,
*Renato T. de Saboya*
Universidade Federal de Santa Catarina
Programa de Pós-Graduação em Arquitetura e Urbanismo (PósArq)
GP Urbanidades <http://urbanidades.sites.ufsc.br> | Orcid
<https://orcid.org/0000-0003-4631-1413> | ResearchGate
<http://www.researchgate.net/profile/Renato_Saboya>
On Wed, 25 Sep 2019 at 20:49, C Craig Farquhar <ccfarquhar at gmail.com> wrote:
> I'm using QGIS Zanzibar (64 bit, standalone):
> QGIS version
> 3.8.3-Zanzibar
> QGIS code revision
> 685d8b15d2 <https://github.com/qgis/QGIS/commit/685d8b15d2>
> Compiled against Qt
> 5.11.2
> Running against Qt
> 5.11.2
> Compiled against GDAL/OGR
> 2.4.1
> Running against GDAL/OGR
> 2.4.1
> Compiled against GEOS
> 3.7.2-CAPI-1.11.0
> Running against GEOS
> 3.7.2-CAPI-1.11.0 b55d2125
> PostgreSQL Client Version
> 10.8
> SpatiaLite Version
> 4.3.0
> QWT Version
> 6.1.3
> QScintilla2 Version
> 2.10.8
> Compiled against PROJ
> 5.2.0
> Running against PROJ
> Rel. 5.2.0, September 15th, 2018
> OS Version
> Windows 10 (10.0)
> I appreciate this Open Source software but I encounter bugs all the time,
> and frequent crashes.
> Two issues I'm dealing with right now:
> 1) when copying the code (in this case, #1acb9f ) for a color I want in a
> map of state with county outlines, it fills all counties but one (!!??!).
> 2) I'm having great trouble trying to Save a Style, and make it work in
> new maps (same geometry). It seems to save OK but when I call it up from
> Load Style in Symbology, it returns blank! Nothing.
> I may not have provided enough detail for assistance, but will be happy to
> provide whatever is needed to help me through this..
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190927/dd4b8e65/attachment.html>
