[Qgis-user] v.out.ogr finished with error
E Jessome
ejessome at acapcb.ns.ca
Wed Apr 1 16:01:30 PDT 2020
Hola! I am trying to export a GRASS vector file to a shapefile, but keep
getting the following error message (pasted below). I am new to QGIS, and
unsure how to fix this issue so that I can successfully create my watershed
shapefile.
Any suggestions would be much appreciated.
Thank you!
C:/PROGRA~1/QGIS2~1.18/apps/grass/GRASS-~1.2/bin/v.out.ogr.exe
input=MAB01 at CBRM_GRASS layer=1 type=area format=ESRI_Shapefile
output=MAB01.shp output_layer=default -e -c
The map contains islands. With the -c flag, islands will appear as filled
areas, not holes in the output map.
Unable to create OGR layer
Finished with error
Elizabeth Jessome
*Project Specialist*
ACAP Cape Breton
(902) 567-1628 ext. 211
www.acapcb.ns.ca
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200401/a4a10a20/attachment.html>
