[Qgis-user] QGIS windows problem
    Richard Duivenvoorde
    rdmailings at duif.net
    Sat Apr  4 08:25:07 PDT 2020
Besides default F11 to go full screen, there is als:
Ctrl-tab which should hide layermanager and other panels
Ctrl-shift-tab which hides ALL widget stuff, so in combi with F11 can be
use to have a full screen MAP ...without any QGIS related items...
To be found in the bottom of the View menu
Maybe it is one of those?
You can toggle/circle around those
Hope this helps
Regards,
On 4/4/20 1:47 AM, David McAlpin wrote:
> I have an odd problem with the 64-bit version of QGIS, version3.10.4-A
> Coruña.
> Once I load QGIS, its window occupies the entire screen, but it's more
> than merely maximized.  There is no task bar at the bottom, and there
> are no Maximize/Minimize/Close buttons.  I cannot grab the edges of the
> QGIS window to shrink it, nor can I move it out of the way, because
> there's no title bar.  I can only access the desktop with the ALT-ESC
> key-combination.  This moves the QGIS window to the back of all other
> programs that are running, but the QGIS window still cannot be
> maximized, minimized, or closed.  The only way to exit is with the
> [Project-Exit QGIS] menu command.
> All other programs run normally, even those running simultaneously with
> QGIS.  This is annoying as hell, and I feel certain this is a simple
> setting that needs to be changed, but so far it has evaded all my
> efforts to find it.
> Qgis-user mailing list
