[Qgis-user] QGIS windows problem
Phil Wyatt
phil at wyatt-family.com
Fri Apr 3 16:59:17 PDT 2020
Hi David,
Sounds like you are in Full Screen Mode does pressing F11 do anything for
you?
Cheers - Phil
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of David
McAlpin
Sent: Saturday, 4 April 2020 10:48 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] QGIS windows problem
I have an odd problem with the 64-bit version of QGIS, version3.10.4-A
Coruña.
Once I load QGIS, its window occupies the entire screen, but it's more than
merely maximized. There is no task bar at the bottom, and there are no
Maximize/Minimize/Close buttons. I cannot grab the edges of the QGIS window
to shrink it, nor can I move it out of the way, because there's no title
bar. I can only access the desktop with the ALT-ESC key-combination. This
moves the QGIS window to the back of all other programs that are running,
but the QGIS window still cannot be maximized, minimized, or closed. The
only way to exit is with the [Project-Exit QGIS] menu command.
All other programs run normally, even those running simultaneously with
QGIS. This is annoying as hell, and I feel certain this is a simple setting
that needs to be changed, but so far it has evaded all my efforts to find
it.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200404/ab652c41/attachment.html>
