[Qgis-user] QGIS windows problem
David McAlpin
fsdbm2 at msn.com
Fri Apr 3 16:47:52 PDT 2020
I have an odd problem with the 64-bit version of QGIS, version3.10.4-A Coruña.
Once I load QGIS, its window occupies the entire screen, but it's more than merely maximized. There is no task bar at the bottom, and there are no Maximize/Minimize/Close buttons. I cannot grab the edges of the QGIS window to shrink it, nor can I move it out of the way, because there's no title bar. I can only access the desktop with the ALT-ESC key-combination. This moves the QGIS window to the back of all other programs that are running, but the QGIS window still cannot be maximized, minimized, or closed. The only way to exit is with the [Project-Exit QGIS] menu command.
All other programs run normally, even those running simultaneously with QGIS. This is annoying as hell, and I feel certain this is a simple setting that needs to be changed, but so far it has evaded all my efforts to find it.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200403/7249dbce/attachment.html>
