[Qgis-user] How to create a hiking map with Qgis and OSM
APM
apschwimmer at apmland.de
Wed Apr 8 00:49:02 PDT 2020
Dear all,
I like to create a hiking map with Qgis and ask you for some help.
My system is a small laptop with Debian stable and Qgis 3.12.1.
As a base I to use the WMS server https://ows.terrestris.de/osm/service
I like to use OSM to avoid trouble due to legal things.
I added a vector layer with WGS84 / UTM 32N and a gps vector layer.
The related gpx file is loaded with the plugin gps tool.
My first question is how to setup a scale 1:10.000?
Maybe it‘s possible to print a map with fixed scale?
Further the printed .pdf has very small letters, which are not readable.
Can I enlarge the letters or is it given by the WMS server?
Generally I like to ask if I have to render a map if I would use a
vector layer based on a OSM .pbf file in every case.
Is there a simple tool for linux to do the rendering?
I found only older tools or a very comlex solution with a comlete server.
Thank you very much for your kindly help!
Kind regards
Axel
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200408/e68eca5b/attachment.html>
