[Qgis-user] How to create a hiking map with Qgis and OSM
Christian Yrrman
yrrman at gmail.com
Wed Apr 8 05:43:35 PDT 2020
Hi Axel,
this relates only vaguely to your question:
1. If it's only for adding gpx to topographic maps, you could use
opentopomap?
https://opentopomap.org/
2. in QGIS, add the QuickMapServices plugin and under "Settings" choose
"More Services". This will add a lot more web services, for example Bergfex
also with topographic look&feel.
This doesn't answer your question, but perhaps it's not completely useless.
Best
Chris
On Wed, Apr 8, 2020 at 12:43 PM Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
wrote:
> Hi,
> Am 08.04.20 um 09:49 schrieb APM:
> Dear all,
> I like to create a hiking map with Qgis and ask you for some help.
> My system is a small laptop with Debian stable and Qgis 3.12.1.
> As a base I to use the WMS server https://ows.terrestris.de/osm/service
> I like to use OSM to avoid trouble due to legal things.
> I added a vector layer with WGS84 / UTM 32N and a gps vector layer.
> The related gpx file is loaded with the plugin gps tool.
> Is it possible, that you use a very old tutorial? For ages it is not
> necessary any more to use the GPS tool plugin to load GPX files, you just
> can drag and drop them into the project.
> My first question is how to setup a scale 1:10.000?
> Maybe it‘s possible to print a map with fixed scale?
> Did you already find the Print Layout? When you draw a map frame there,
> you are of course able to set a scale of your choice in the properties.
> Further the printed .pdf has very small letters, which are not readable.
> Can I enlarge the letters or is it given by the WMS server?
> WMS tiles are normally rendered to serve for screen display. Thats why
> they rarely fit for printing in respect of letters and symbology.
> Generally I like to ask if I have to render a map if I would use a vector
> layer based on a OSM .pbf file in every case.
> Is there a simple tool for linux to do the rendering?
> I found only older tools or a very comlex solution with a comlete server.
> Rendering own maps like WMS-servers do is quite "rocket science". Never
> tried it.
> And adjusting QGIS styles to mimic that is also hard work.
> Furthermore, for a hiking map, you would like to have hillshade and maybe
> contour lines added as well.
> Beware of too old informations in the web. Articles older than let's say 2
> years will be most probably outdated.
> And my feeling is, that support and integration of OSM-data in QGIS got
> worse in the last years (missing plugins, lot of confusion)
> But as I am not expert in this field, someone with more knowledge should
> chime in here.
> Cheers,
> Bernd
> Thank you very much for your kindly help!
> Kind regards
> Axel
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200408/3160f0b1/attachment.html>
