[Qgis-user] Using r.contour with QGIS 3.12
Dave Marshall 43carnaby at gmail.com
Wed Apr 8 15:05:05 PDT 2020
Hello,
I've just upgraded to 3.12 from 3.4 and when working with LIDAR data I find
that r.contour no longer works. The first warning which occurs is: Datum
<Unknown_based_on_Airy_1830_ellipsoid> not recognised by GRASS and no
parameters found
Further error messages are: Datum <Unknown_based_on_Airy_1830_ellipsoid>
not recognised by GRASS and no parameters found
WARNING: Unable to open vector map
<output4a2f59f8cf014c4d8b8b782e7d15854a at PERMANENT> on level 2. Try to
rebuild vector topology with v.build.
ERROR: Unable to open vector map <output4a2f59f8cf014c4d8b8b782e7d15854a>
and finally a message saying the layers were not correctly generated.
This routine worked perfectly in version 3.4.
Is there a simple fix? I am using OSGB 1936 / British National Grid
[EPSG:27700] as CRS.
Thanks,
Dave Marshall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200408/32298379/attachment.html>
