[Qgis-user] Using r.contour with QGIS 3.12
Christoph Jung
jagodki.cj at gmail.com
Thu Apr 9 02:29:07 PDT 2020
Hello Dave,
I am not very familiar with the grass tools and its error messages. But as an alternative you could use gdal_contour to generate contour lines from a raster layer.
Sincerely,
Christoph
> Am 09.04.2020 um 00:05 schrieb Dave Marshall <43carnaby at gmail.com>:
> Hello,
> I've just upgraded to 3.12 from 3.4 and when working with LIDAR data I find that r.contour no longer works. The first warning which occurs is: Datum <Unknown_based_on_Airy_1830_ellipsoid> not recognised by GRASS and no parameters found
> Further error messages are: Datum <Unknown_based_on_Airy_1830_ellipsoid> not recognised by GRASS and no parameters found
> WARNING: Unable to open vector map <output4a2f59f8cf014c4d8b8b782e7d15854a at PERMANENT> on level 2. Try to rebuild vector topology with v.build.
> ERROR: Unable to open vector map <output4a2f59f8cf014c4d8b8b782e7d15854a>
> and finally a message saying the layers were not correctly generated.
> This routine worked perfectly in version 3.4.
> Is there a simple fix? I am using OSGB 1936 / British National Grid [EPSG:27700] as CRS.
> Thanks,
> Dave Marshall
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200409/f6a767e2/attachment-0001.html>
