[Qgis-user] Query on QgsVectorLayer
Christoph Jung
jagodki.cj at gmail.com
Thu Apr 9 11:56:00 PDT 2020
Hello Werner,
Thank you for your advice. But I need the geometry with the max/min x-value, i.e. the bounding box values will not be enough.
Sincerely,
Christoph
> Am 09.04.2020 um 16:19 schrieb Werner Macho <werner.macho at gmail.com>:
> Hi!
> If you really only want the highest/lowest X-Value - what about
> querying the Bounding Box of the layer?
> Maybe that will also result in what you want.
> regards
> Werner
>> On Thu, 2020-04-09 at 13:37 +0200, Christoph Jung wrote:
>> Hello everyone,
>> I have a question concerning PyQGIS. Imagine there is a point layer
>> accessed via QgsVectorLayer, i.e. no matter which data source it is.
>> Is it possible to query this layer to get the point object with the
>> highest/lowest x-value in its geometry (similar to max-/min-aggregate
>> functions in SQL)? Or do I have to iterate over all objects and
>> compare the values by my own?
>> Sincerely,
>> Christoph
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
