[Qgis-user] ISSUE QGIS keeps freezing - QGIS Desktop 3.10.4
Koos Fransen Koos.Fransen at vub.be
Thu Apr 9 23:55:39 PDT 2020
Dear Bo and Andreas
Thank you very much for your insights.
Given the fact that QGIS has been more stable since yesterday, I think the problem was related to my hard drive memory and temporary files. I did not have a lot of space left on the hard drive, and I tend do leave my computer on when calling it a day, so maybe that combination was not very helpful for QGIS to work smoothly.
I’ve deleted some data on my laptop, thus freeing up some space and, as you said, I deleted my temp files for QGIS (I had been working with very large datasets), and for now everything works quite well. I’ll also start shutting off my laptop from time to time 😉
I’ll keep you posted if it should occur again and if I can find a clear solution to the problem. Anyway, Bo, you and your wife’s list is a very good starting point to start problem solving with should this issue occur again. There are some things that I can exclude as reason (build is the stable 3.10 version, it’s not the anti-virus, it’s not a work network environment, …), and some things that I still have to test. Many thanks for your help (and good luck with the teaching assignment, I’m teaching introductory courses in GIS at Vrije Universiteit Brussel, but one of the next things I would like to dive into is the use of PostGIS and PostgreSQL for my own research)!
Kind regards
Koos
dr. Koos Fransen
Research unit Cosmopolis (VUB)
Research unit ISE (UGent)
I am available for VUB on Tuesdays, Thursdays and Fridays and for UGent on Mondays and Wednesdays. Consequently, I try to structure meetings accordingly and answers to your mails may be delayed.
Sent: donderdag 9 april 2020 17:27
To: Bo Victor Thomsen <bo.victor.thomsen at gmail.com>; Koos Fransen <Koos.Fransen at vub.be>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] ISSUE QGIS keeps freezing - QGIS Desktop 3.10.4
These are all good points. I also had severe issues with Antivirus - it slowed down or prevented a lot of the network access. The IT services had to add exceptions.
But you describe that it only happens after a couple of days of usage, which is strange.
If you find out what the issues really is, please let us know, so we can learn.
Andreas
Am 09.04.20 um 15:20 schrieb Bo Victor Thomsen:
Hi Koos -
I had a talk with my wife Lene Fischer about your issues. (She is a Assoc. Prof. teaching GIS at a department of the University of Copenhagen using QGIS. I co-lecture with her on the use of spatial enabled databases (PostgreSQL/ PostGIS)).
She hasn't experienced the issues you describe (but some other issues)
Here is some pointers:
  *   Use a long-term releases and keep up with the point releases 3.10.3 -> 3.10.4 (Which you do :-)
  *   Clean the temp dir regularly (Which you did :-)
  *   Check the setup of your windows pointers to user-dirs, temp space. Sometimes they are not suited for computers outside the university network (or inside, if the network sucks)
  *   Check if your logon name contains special characters outside us-ASCII like accented character or blanks. QGIS is fine with these but some add-on libraries is not. The logon name can be a part of a path name that something chokes on.
  *   Check your antivirus by temporarily disable it before using QGIS.
  *   Check your disk space. The temp dir  can "grow" considerably during QGIS use.
  *   Check the amount of memory used on your computer.  If you are using all available ram you will get the symptoms you describe
  *   Install a minimum of plugins.
  *   Keep your windows installation as clean as possible. QGIS might conflict with some other software installed on your computer. You might try to install QGIS on computer with a new clean install of windows. Check if the error is repeated on the new computer.
  *   You might try with installing QGIS from the "network installer" utility instead of a stand-alone installation (https://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe). It defaults to another installation directory than the stand-alone installation. That might help.
  *   If nothing of the above works - try another version of QGIS i.e. 3.12.1.
The network installer  has the possibility to install a "bleeding edge" version of QGIS but I won't recommend using these in a teaching situation (or any other situation which involves inexperienced users). But you can use it in a testing situation
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 09-04-2020 kl. 11:20 skrev Koos Fransen:
Hi Bo
Thanks for your quick response!
Sorry for the minimal information provided, I wasn’t sure what to add (first question to the QGIS user list).
To answer your questions:
OS: Windows 10 – 64 bit
QGIS version: 3.10.4 64 bit, stand-alone installation
I’m not in any networked set-up, I’m working from home on my own computer. I have only one plugin installed (QuickOSM), and I’ve already tried uninstalling, but without any difference.
Since my question I’ve been trying some things, and I have deleted the temporary QGIS files in my Local/Temp folder. When I open and use QGIS now, I have the feeling it’s more stable again. It gives a hint of freezing up at the start, but afterwards all goes quite well again. Then again, not sure of this is a solid solution for fixing this issue, as I have experienced this issue before completely deleting and reinstalling everything QGIS-related on my laptop (using REVO uninstaller). After this, QGIS worked fine for about a week until today.
I do recall trying to load some large files into QGIS, maybe they were stored in a temporary directory somewhere and deleting the temporary files helped?
Anyways, it might be relevant for me to know. I’ve switched our courses from ArcGIS to QGIS, and I’m really happy about it, but I would like to be able to help my students if these kind of problems occur.
Thank for the help already, not sure if there’s more to do for now, but let me know if you have any more ideas.
Kind regards
Koos
dr. Koos Fransen
From: Qgis-user <qgis-user-bounces at lists.osgeo.org><mailto:qgis-user-bounces at lists.osgeo.org> On Behalf Of Bo Victor Thomsen
Sent: donderdag 9 april 2020 10:16
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Hi Koos:
That's not much information to go on.
What about: OS type and version ?  32/64 bit os ?  QGIS version ? QGIS 32/64 bit ? network environment ? Normal stand-alone installation or Network installation ?
I'll hazard a guess based on my own painful experiences: You are working  in a networked windows setup, where your IT department has made some modifications for home directory (including temp file placement) and/or the userdata environment - maybe making it fully dependant on the network. And maybe You are using the same login account for all pupils. Combine this with a marginally functioning network and it will be a train wreck
Another  scenario: You have installed some plugin, that's not working correctly.
What you can test:
  *   Disable/Remove all plugins from QGIS and test if the problem goes away
  *   Load some GIS data locally on you computer and disconnect the computer from the network. Then test QGIS again.
That said, QGIS ver. 3.10 onwards has long startup times. However it's quick and stable after that
Bo Victor Thomsen
Den 09-04-2020 kl. 09:46 skrev Koos Fransen:
Dear all
I have a question regarding QGIS.
I’m using QGIS for my classes, but since a recent install my QGIS keeps freezing right after startup. It doesn’t respond until after a minute, then I can open some files and then it freezes again. This keeps on going, making it impossible to keep working with QGIS.
I’ve tried reinstalling, which always helps at first, but after a couple of days it starts freezing again. I’ve also tried with different versions, with the same result.
It might maybe have something to do with temporary files?
Has someone experienced the same issue, and are there possible solutions that you know of?
Thanks!
Koos
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200410/1a3b3cba/attachment.html>
