[Qgis-user] ISSUE QGIS keeps freezing - QGIS Desktop 3.10.4
Andreas Neumann
a.neumann at carto.net
Thu Apr 9 08:27:24 PDT 2020
These are all good points. I also had severe issues with Antivirus - it
slowed down or prevented a lot of the network access. The IT services
had to add exceptions.
But you describe that it only happens after a couple of days of usage,
which is strange.
If you find out what the issues really is, please let us know, so we can
learn.
Andreas
Am 09.04.20 um 15:20 schrieb Bo Victor Thomsen:
> Hi Koos -
> I had a talk with my wife Lene Fischer about your issues. (She is a
> Assoc. Prof. teaching GIS at a department of the University of
> Copenhagen using QGIS. I co-lecture with her on the use of spatial
> enabled databases (PostgreSQL/ PostGIS)).
> She hasn't experienced the issues you describe (but some other issues)
> Here is some pointers:
> * Use a long-term releases and keep up with the point releases
> 3.10.3 -> 3.10.4 (Which you do :-)
> * Clean the temp dir regularly (Which you did :-)
> * Check the setup of your windows pointers to user-dirs, temp space.
> Sometimes they are not suited for computers outside the university
> network (or inside, if the network sucks)
> * Check if your logon name contains special characters outside
> us-ASCII like accented character or blanks. QGIS is fine with
> these but some add-on libraries is not. The logon name can be a
> part of a path name that something chokes on.
> * Check your antivirus by temporarily disable it before using QGIS.
> * Check your disk space. The temp dir can "grow" considerably
> during QGIS use.
> * Check the amount of memory used on your computer. If you *are*
> using all available ram you *will* get the symptoms you describe
> * Install a minimum of plugins.
> * Keep your windows installation as clean as possible. QGIS might
> conflict with some other software installed on your computer. You
> might try to install QGIS on computer with a new clean install of
> windows. Check if the error is repeated on the new computer.
> * You might try with installing QGIS from the "network installer"
> utility instead of a stand-alone installation
> (https://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe). It
> defaults to another installation directory than the stand-alone
> installation. That might help.
> * If nothing of the above works - try another version of QGIS i.e.
> 3.12.1.
> The network installer has the possibility to install a "bleeding
> edge" version of QGIS but I won't recommend using these in a
> teaching situation (or any other situation which involves
> inexperienced users). But you can use it in a testing situation
> Med venlig hilsen / Kind regards
> Bo Victor Thomsen
> Den 09-04-2020 kl. 11:20 skrev Koos Fransen:
>> Hi Bo
>> Thanks for your quick response!
>> Sorry for the minimal information provided, I wasn’t sure what to add
>> (first question to the QGIS user list).
>> To answer your questions:
>> OS: Windows 10 – 64 bit
>> QGIS version: 3.10.4 64 bit, stand-alone installation
>> I’m not in any networked set-up, I’m working from home on my own
>> computer. I have only one plugin installed (QuickOSM), and I’ve
>> already tried uninstalling, but without any difference.
>> Since my question I’ve been trying some things, and I have deleted
>> the temporary QGIS files in my Local/Temp folder. When I open and use
>> QGIS now, I have the feeling it’s more stable again. It gives a hint
>> of freezing up at the start, but afterwards all goes quite well
>> again. Then again, not sure of this is a solid solution for fixing
>> this issue, as I have experienced this issue before completely
>> deleting and reinstalling everything QGIS-related on my laptop (using
>> REVO uninstaller). After this, QGIS worked fine for about a week
>> until today.
>> I do recall trying to load some large files into QGIS, maybe they
>> were stored in a temporary directory somewhere and deleting the
>> temporary files helped?
>> Anyways, it might be relevant for me to know. I’ve switched our
>> courses from ArcGIS to QGIS, and I’m really happy about it, but I
>> would like to be able to help my students if these kind of problems
>> occur.
>> Thank for the help already, not sure if there’s more to do for now,
>> but let me know if you have any more ideas.
>> Kind regards
>> Koos
>> *dr. Koos Fransen*
>> Research unit Cosmopolis (VUB)
>> Research unit ISE (UGent)**
>> I am available for _VUB_ on _Tuesdays, Thursdays and Fridays_ and for
>> UGent on Mondays and Wednesdays. Consequently, I try to structure
>> meetings accordingly and answers to your mails may be delayed.
>> *From:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of
>> *Bo Victor Thomsen
>> *Sent:* donderdag 9 april 2020 10:16
>> *To:* qgis-user at lists.osgeo.org
>> *Subject:* Re: [Qgis-user] ISSUE QGIS keeps freezing - QGIS Desktop
>> 3.10.4
>> Hi Koos:
>> That's not much information to go on.
>> What about: OS type and version ? 32/64 bit os ? QGIS version ?
>> QGIS 32/64 bit ? network environment ? Normal stand-alone
>> installation or Network installation ?
>> I'll hazard a *guess* based on my own painful experiences: You are
>> working in a networked windows setup, where your IT department has
>> made some modifications for home directory (including temp file
>> placement) and/or the userdata environment - maybe making it fully
>> dependant on the network. And maybe You are using the same login
>> account for all pupils. Combine this with a marginally functioning
>> network and it will be a train wreck
>> Another scenario: You have installed some plugin, that's not working
>> correctly.
>> What you can test:
>> * Disable/Remove all plugins from QGIS and test if the problem goes
>> away
>> * Load some GIS data locally on you computer and disconnect the
>> computer from the network. Then test QGIS again.
>> That said, QGIS ver. 3.10 onwards has long startup times. However
>> it's quick and stable after that
>> Bo Victor Thomsen
>> Den 09-04-2020 kl. 09:46 skrev Koos Fransen:
>> Dear all
>> I have a question regarding QGIS.
>> I’m using QGIS for my classes, but since a recent install my QGIS
>> keeps freezing right after startup. It doesn’t respond until
>> after a minute, then I can open some files and then it freezes
>> again. This keeps on going, making it impossible to keep working
>> with QGIS.
>> I’ve tried reinstalling, which always helps at first, but after a
>> couple of days it starts freezing again. I’ve also tried with
>> different versions, with the same result.
>> It might maybe have something to do with temporary files?
>> Has someone experienced the same issue, and are there possible
>> solutions that you know of?
>> Thanks!
>> Koos
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200409/8167cd5f/attachment-0001.html>
