[Qgis-user] ISSUE QGIS keeps freezing - QGIS Desktop 3.10.4
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Apr 9 06:20:47 PDT 2020
Hi Koos -
I had a talk with my wife Lene Fischer about your issues. (She is a
Assoc. Prof. teaching GIS at a department of the University of
Copenhagen using QGIS. I co-lecture with her on the use of spatial
enabled databases (PostgreSQL/ PostGIS)).
She hasn't experienced the issues you describe (but some other issues)
Here is some pointers:
  * Use a long-term releases and keep up with the point releases 3.10.3
    -> 3.10.4 (Which you do :-)
  * Clean the temp dir regularly (Which you did :-)
  * Check the setup of your windows pointers to user-dirs, temp space.
    Sometimes they are not suited for computers outside the university
    network (or inside, if the network sucks)
  * Check if your logon name contains special characters outside
    us-ASCII like accented character or blanks. QGIS is fine with these
    but some add-on libraries is not. The logon name can be a part of a
    path name that something chokes on.
  * Check your antivirus by temporarily disable it before using QGIS.
  * Check your disk space. The temp dir  can "grow" considerably during
    QGIS use.
  * Check the amount of memory used on your computer.  If you *are*
    using all available ram you *will* get the symptoms you describe
  * Install a minimum of plugins.
  * Keep your windows installation as clean as possible. QGIS might
    conflict with some other software installed on your computer. You
    might try to install QGIS on computer with a new clean install of
    windows. Check if the error is repeated on the new computer.
  * You might try with installing QGIS from the "network installer"
    utility instead of a stand-alone installation
    (https://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe). It
    defaults to another installation directory than the stand-alone
    installation. That might help.
  * If nothing of the above works - try another version of QGIS i.e.
    3.12.1.
    The network installer  has the possibility to install a "bleeding
    edge" version of QGIS but I won't recommend using these in a
    teaching situation (or any other situation which involves
    inexperienced users). But you can use it in a testing situation
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 09-04-2020 kl. 11:20 skrev Koos Fransen:
> Hi Bo
> Thanks for your quick response!
> Sorry for the minimal information provided, I wasn’t sure what to add
> (first question to the QGIS user list).
> To answer your questions:
> OS: Windows 10 – 64 bit
> QGIS version: 3.10.4 64 bit, stand-alone installation
> I’m not in any networked set-up, I’m working from home on my own
> computer. I have only one plugin installed (QuickOSM), and I’ve
> already tried uninstalling, but without any difference.
> Since my question I’ve been trying some things, and I have deleted the
> temporary QGIS files in my Local/Temp folder. When I open and use QGIS
> now, I have the feeling it’s more stable again. It gives a hint of
> freezing up at the start, but afterwards all goes quite well again.
> Then again, not sure of this is a solid solution for fixing this
> issue, as I have experienced this issue before completely deleting and
> reinstalling everything QGIS-related on my laptop (using REVO
> uninstaller). After this, QGIS worked fine for about a week until today.
> I do recall trying to load some large files into QGIS, maybe they were
> stored in a temporary directory somewhere and deleting the temporary
> files helped?
> Anyways, it might be relevant for me to know. I’ve switched our
> courses from ArcGIS to QGIS, and I’m really happy about it, but I
> would like to be able to help my students if these kind of problems occur.
> Thank for the help already, not sure if there’s more to do for now,
> but let me know if you have any more ideas.
> Kind regards
> Koos
> *dr. Koos Fransen*
> Research unit Cosmopolis (VUB)
> Research unit ISE (UGent)**
> I am available for _VUB_ on _Tuesdays, Thursdays and Fridays_ and for
> UGent on Mondays and Wednesdays. Consequently, I try to structure
> meetings accordingly and answers to your mails may be delayed.
> *From:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Bo
> Victor Thomsen
> *Sent:* donderdag 9 april 2020 10:16
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] ISSUE QGIS keeps freezing - QGIS Desktop 3.10.4
> Hi Koos:
> That's not much information to go on.
> What about: OS type and version ?  32/64 bit os ?  QGIS version ? QGIS
> 32/64 bit ? network environment ? Normal stand-alone installation or
> Network installation ?
> I'll hazard a *guess* based on my own painful experiences: You are
> working  in a networked windows setup, where your IT department has
> made some modifications for home directory (including temp file
> placement) and/or the userdata environment - maybe making it fully
> dependant on the network. And maybe You are using the same login
> account for all pupils. Combine this with a marginally functioning
> network and it will be a train wreck
> Another  scenario: You have installed some plugin, that's not working
> correctly.
> What you can test:
>   * Disable/Remove all plugins from QGIS and test if the problem goes
>     away
>   * Load some GIS data locally on you computer and disconnect the
>     computer from the network. Then test QGIS again.
> That said, QGIS ver. 3.10 onwards has long startup times. However it's
> quick and stable after that
> Bo Victor Thomsen
> Den 09-04-2020 kl. 09:46 skrev Koos Fransen:
>     Dear all
>     I have a question regarding QGIS.
>     I’m using QGIS for my classes, but since a recent install my QGIS
>     keeps freezing right after startup. It doesn’t respond until after
>     a minute, then I can open some files and then it freezes again.
>     This keeps on going, making it impossible to keep working with QGIS.
>     I’ve tried reinstalling, which always helps at first, but after a
>     couple of days it starts freezing again. I’ve also tried with
>     different versions, with the same result.
>     It might maybe have something to do with temporary files?
>     Has someone experienced the same issue, and are there possible
>     solutions that you know of?
>     Thanks!
>     Koos
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org  <mailto:Qgis-user at lists.osgeo.org>
>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200409/6019ad60/attachment.html>
