[Qgis-user] QGIS Server and webmapping information
Alessandro Pasotti
apasotti at gmail.com
Fri Apr 10 06:14:45 PDT 2020
On Fri, Apr 10, 2020 at 3:05 PM Etienne Trimaille
<etienne.trimaille at gmail.com> wrote:
> Hi,
> qgis2web will generate a static website that you can easily move on a server somewhere, without the need to install QGIS Server.
> The website will be generated from the plugin itself.
> If you install QGIS Server only, you will have only some OGC streams such as WMS, WFS etc. It's just to publish "data" on the internet. But you won't have the web viewer in an internet browser.
> Then you need to code the web application using Leaflet or OpenLayers.
That's not entirely correct anymore because WFS3 provides a very
simple browsable website, see
https://docs.qgis.org/3.10/en/docs/user_manual/working_with_ogc/server/services.html#wfs3-ogc-api-features
You could easily override the default HTML templates to show your WMS
layers too, no need to rebuild or compile anything.
Cheers
Alessandro Pasotti
w3: www.itopen.it
