[Qgis-user] QGIS Server and webmapping information
Etienne Trimaille
etienne.trimaille at gmail.com
Fri Apr 10 06:05:01 PDT 2020
qgis2web will generate a static website that you can easily move on a
server somewhere, without the need to install QGIS Server.
The website will be generated from the plugin itself.
If you install QGIS Server only, you will have only some OGC streams such
as WMS, WFS etc. It's just to publish "data" on the internet. But you won't
have the web viewer in an internet browser.
Then you need to code the web application using Leaflet or OpenLayers.
If you use QGIS Web Client, Lizmap or similar, the web application is
already there and will offer some widgets and some tools. It will try to
mimic the QGIS Desktop application with the layer tree, the print layouts,
dataviz etc.
I tried to make this schema :
https://docs.lizmap.com/next/en/introduction.html I hope it can help you.
There are a few QGIS web applications : QGIS Web Client, Lizmap, GisQuick,
Mappia
Le ven. 10 avr. 2020 à 14:04, Franko Naimarevic <Franko.Naimarevic at ulb.ac.be>
a écrit :
> Hello,
> I'm a final-year architecture student, and as part of my thesis, I'm
> researching on how to publish a map made in QGIS on the internet, in
> hopes of doing so later myself.
> I've heard that the qgis2web plugin was a great option, but I've also
> found that it was possible to do with QGIS Server. However, I haven't
> managed to find a lot of "theoretical" explanations about it, plus, I'm
> really not that familiar with this webmapping/GIS "world". So, I was
> hoping someone could clarify things for me, as completely as possible.
> I understand the main step is to install it on a server, obviously. But
> what are the other things that have to be done in order to publish an
> interactive QGIS map on the internet?
> For example, I'm wondering at what point are the widgets (for
> navigation, search bar, ...) defined to appear on the webpage?
> Also, QGIS Server and QGIS Web Client seem to work together ; what is
> their role in that relationship? Is it a necessity?
> Thanks in advance for your help,
> Franko
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200410/736d66f1/attachment.html>
