[Qgis-user] Pavement defects Identification
Richard McDonnell
richard.mcdonnell at opw.ie
Tue Apr 14 01:52:22 PDT 2020
It would be possible, though it would depend on the raster and the bands (Red, Green, Blue, NIR etc..)you have available. It could be possible to use raster Classification to map these features, though I believe you would have quite a lot of false positives, due to shadowing, surface finish changes..etc..
If you where to look at it I would recommend the Semi-Automatic Classification Plugin
https://fromgistors.blogspot.com/p/semi-automatic-classification-plugin.html
It can be installed through the Plugin installer.
Please also see the Link below, it may be of further interest.
https://link.springer.com/article/10.1007/s12544-015-0156-6
As you may see from the above, it does suggest that you supplement the Raster Imagery with additional datasets, which should help in the detection of road defects and the overall accuracy of your results.
Sorry I cant be of more help, hopefully the above will help in some way.
Regards,
Richard.
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 1 647 6543
https://www.opw.ie
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.opw.ie/en/disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of krishna Ayyala
Sent: 10 April 2020 16:02
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Pavement defects Identification
Hello,
Is it possible to identify the pavement defects using a raster image with QGIS? If there is any tutorial about this, can you please direct me the tutorial.
Regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200414/e9d6d384/attachment.html>
