[Qgis-user] Pavement defects Identification
Christoph Jung
jagodki.cj at gmail.com
Tue Apr 14 05:18:23 PDT 2020
My experienced in the field of road surface and condition survey is, that it is a very tough task to create a robust procedure. There are so many outliers and special situations. Because of this, many companies evaluate the raster images manually anymore. A state of the art method would be deep learning using a convolutional neural network. The Technical University Ilmenau (Germany) has a project group working on this topic with very good results.
If you have just a small area with big, easy detectable defects, than it could be possible using the semi automatic classification plugin mentioned before.
Sincerely,
Christoph
>> Am 10.04.2020 um 17:02 schrieb krishna Ayyala <ayyalakrishna at gmail.com>:
> Hello,
> Is it possible to identify the pavement defects using a raster image with QGIS? If there is any tutorial about this, can you please direct me the tutorial.
> Regards.
> Qgis-user mailing list
