[Qgis-user] Refresh Layer at Interval not working
Raymond Nijssen r.nijssen at terglobo.nl
Tue Apr 14 03:40:08 PDT 2020
Hi Ayyala,
Since the option is in the tab called "Render" I think it will only
re-render the layer and not reload the data.
I tried this:
- create 3 points in a geojson layer
- set a 2 sec refresh interval on it
- open the geojson file in a text editor and add an extra point
- save geojson
The extra point should show up within 2 seconds in qgis but it does not.
Even after panning or zooming it does not show up. I think it would if I
used a postgis layer or a shp-file? Could this be dependent on the data
format?
If you need an example of a refreshed layer, you can type "hackfests" in
the Coordinate input at the bottom. It will show you the hackfest
locations with "moving" markers.
@other users: Does QGIS have an option to reload data for a layer? In
the GUI, similar to the "Update Extents" button?
Kind regards,
Raymond
On 14-04-2020 05:04, krishna Ayyala wrote:
> Hello,
> I have a shape file as below. I have checked the box "Refresh Layer at
> Interval" for 1 second. The layer isĀ  not refreshing.
> Regards.
> Qgis-user mailing list
