[Qgis-user] Refresh Layer at Interval not working
Richard Duivenvoorde
rdmailings at duif.net
Tue Apr 14 12:03:35 PDT 2020
I've created a minimal script which generates a random point, more or
less in The Netherlands..:
https://duif.net/cgi-bin/gj.py
If you load that script as a vector layer /Protocol/GeoJSON you will see
one point in The Netherlands.
Upon hitting F5 (menu: View/Refresh), you will see the dot moving as it
is requesting the data everytime..
For what I know this worked for all datasources?
Not sure if this is what you try to achieve, but that is also possible
with python (though I do not have it with me here...)
Regards,
On 4/14/20 12:40 PM, Raymond Nijssen wrote:
> Hi Ayyala,
> Since the option is in the tab called "Render" I think it will only
> re-render the layer and not reload the data.
> I tried this:
> - create 3 points in a geojson layer
> - set a 2 sec refresh interval on it
> - open the geojson file in a text editor and add an extra point
> - save geojson
> The extra point should show up within 2 seconds in qgis but it does not.
> Even after panning or zooming it does not show up. I think it would if I
> used a postgis layer or a shp-file? Could this be dependent on the data
> format?
> If you need an example of a refreshed layer, you can type "hackfests" in
> the Coordinate input at the bottom. It will show you the hackfest
> locations with "moving" markers.
> @other users: Does QGIS have an option to reload data for a layer? In
> the GUI, similar to the "Update Extents" button?
> Kind regards,
> Raymond
> On 14-04-2020 05:04, krishna Ayyala wrote:
>> Hello,
>> I have a shape file as below. I have checked the box "Refresh Layer at
>> Interval" for 1 second. The layer isĀ not refreshing.
>> Regards.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
