[Qgis-user] re-distributing randomly points within an existing polygon file
Håvard Tveite
havard.tveite at nmbu.no
Thu Apr 16 15:35:43 PDT 2020
The "Random points inside polygons" algorithm could be of
some help. In the upcoming (?) "Random points in polygons"
algorithm (https://github.com/qgis/QGIS/pull/35745), it is
possible to "data define" the number of points for each
polygon, so when / if that algorithm becomes available,
you just need to make sure that you have an attribute to
your polygon layer that gives the count of households that
are inside the polygon (can be generated from your
households points using the "Join attributes by location
(summary)" algorithm).
When the random points have been generated, you have to
find a way to join your existing households to the
generated points.
Håvard
On 16.04.2020 23:03, Robert Sweeny wrote:
> I have 50k+ points representing all the heads of household in Montreal
> in 1901, which I have linked to their specific lot, one of 20k+ built
> lots in the city at the time. Many lots have large number of dots,
> hotels and apartment buildings for example, while others frequently have
> up to 15 on a single lot. Currently they are all grouped together, not
> on top of each other, but almost. I would like to re-distribute them
> evenly over the space of the lot, so they would be more visible. Any
> suggestions on how I should proceed?
> Thanks in advance
> Robert Sweeny
> Qgis-user mailing list
