[Qgis-user] Labels within a bubble callouts
krishna Ayyala
ayyalakrishna at gmail.com
Thu Apr 16 17:33:41 PDT 2020
Yes, I imported using the background on the labels tab. Still the same
issue. Able to see the bubble callout as an image. Unable to tweak or
resize the callout. Label text is also completely out of the bubble callout.
On Thu, Apr 16, 2020 at 10:22 AM David Strip <david at stripfamily.net> wrote:
> Le 16 avr. 2020 à 09:33, krishna Ayyala <ayyalakrishna at gmail.com>
> <ayyalakrishna at gmail.com> a écrit :
> Good Morning Nicolas,
> Thanks for your reply. In the SVG images library, there is no bubble
> callout symbol. I created one bubble callout symbol and saved it as an svg
> file. I tried to import this symbol into the map. It is just showing as an
> image. I cannot do anything with it. The whole purpose is; after labeling
> the points layer with bubble callouts, I want to tweak them and position
> them at appropriate places for each point within the shape file. Just
> similar to the text annotation in QGIS. Any leads on this please?
> Regards.
> What do you mean when you say you "imported this symbol"? Are you using it
> as the symbol in the symbology tab of the properties? If so, that's not
> right. You want to use it as the background on the Labels tab.
> If you can, help others; if you cannot do that, at least do not harm them.
> * Dalai Lama*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200416/1e76114e/attachment.html>
