[Qgis-user] Creating raster difference for many small rasters
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Apr 17 11:36:27 PDT 2020
Can you use the zonal statistics in the processing tools? It’s not the plugin.
Nicolas Cadieux
Ça va bien aller!
> Le 17 avr. 2020 à 11:04, joolek <joolek.o at gmail.com> a écrit :
> Hi Everyone,
> I have failed looking for a solution. And using latest QGIS so can't use Zonal Statistic Plugin
> I basically have almost a hundred of small asc grids, from two different data sets. They overlap and I'd like to calculate difference between them... not as a one value but difference for each overlapping raster.
> I also do have them vectorized.
> As mentioned I have tried Zonal Statistic Plugin but it doesn't work on new QGIS.
> Does anyone have experience and could advise?
> Maaaaaaaaaaaaasive thank you!!
> Qgis-user mailing list
