[Qgis-user] Shared line-style resources etc
Phil Wyatt
phil at wyatt-family.com
Sun Apr 19 21:03:56 PDT 2020
Hi Tony,
A lot of styling depends on the attributes of the layer so you can really
only pass around QML files for common layers. I have some to match the
Tasmanian LIST system common use layers (roads, hydrology etc)
https://listdata.thelist.tas.gov.au/opendata/
Are you specifically after some to match common NZ data downloads? I did
some styles a while ago for a project on the Auckland Islands using the 150K
topo data. You are welcome to those if they help at all
Cheers - Phil
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Tony
Shepherd (FarmMaps NZ)
Sent: Monday, 20 April 2020 11:07 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Shared line-style resources etc
Hi All
Hope that averyone is getting through whatever lockdown conditions you are
under ok. Day 26 for us in New Zealand.
I'm just wondering of any known shared resources for line styles, point
styles, svg libraries etc? I have done some searching on the web and found
a few things scattered here and there but nothing really substantial. I
imagined with QGIS being opensource and loads of plugins being shared that
there may be a similar resource for styles etc.
Cheers
Tony
Tony Shepherd | GeoSpatial / Mapping Manager
Ph 027 435 6193 | E tony at farmmaps.nz <mailto:tony at farmmaps.nz>
FarmMaps NZ, 3 Kerwood Place, Gore 9740
<http://tonyshepherd8.wixsite.com/home>
<https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE
2>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200420/b72204c8/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200420/b72204c8/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200420/b72204c8/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200420/b72204c8/attachment-0003.png>
