[Qgis-user] Shared line-style resources etc
Paolo Cavallini
cavallini at faunalia.it
Mon Apr 20 00:18:30 PDT 2020
Hi Tony,
there is also a Resource Sharing plugin that is designed exactly for this.
All the best.
Il 20/04/20 06:03, Phil Wyatt ha scritto:
> Hi Tony,
> A lot of styling depends on the attributes of the layer so you can
> really only pass around QML files for common layers. I have some to
> match the Tasmanian LIST system common use layers (roads, hydrology etc)
> https://listdata.thelist.tas.gov.au/opendata/
> Are you specifically after some to match common NZ data downloads? I did
> some styles a while ago for a project on the Auckland Islands using the
> 150K topo data. You are welcome to those if they help at all
> Cheers - Phil
> *From:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Tony
> Shepherd (FarmMaps NZ)
> *Sent:* Monday, 20 April 2020 11:07 AM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Shared line-style resources etc
> Hi All
> Hope that averyone is getting through whatever lockdown conditions you
> are under ok. Day 26 for us in New Zealand.
> I’m just wondering of any known shared resources for line styles, point
> styles, svg libraries etc? I have done some searching on the web and
> found a few things scattered here and there but nothing really
> substantial. I imagined with QGIS being opensource and loads of plugins
> being shared that there may be a similar resource for styles etc.
> Cheers
> Tony
> *Tony Shepherd* *|* GeoSpatial / Mapping Manager
> Ph 027 435 6193 *|* E tony at farmmaps.nz <mailto:tony at farmmaps.nz>
> FarmMaps NZ, 3 Kerwood Place, Gore 9740
> FM_logo1_small (Custom)
> ** <http://tonyshepherd8.wixsite.com/home>**
> <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>**
> Qgis-user mailing list
Paolo Cavallini - QGIS.ORG Chair
www.faunalia.eu:
training, support, development on QGIS, PostGIS and more
