[Qgis-user] Shared line-style resources etc
Håvard Tveite
havard.tveite at nmbu.no
Mon Apr 20 00:25:21 PDT 2020
And here is the link to the documentation of the Resource
Sharing plugin and Resource Sharing in QGIS:
http://qgis-contribution.github.io/QGIS-ResourceSharing/
On 20.04.2020 09:17, Paolo Cavallini wrote:
> Hi Tony,
> there is also a Resource Sharing plugin that is designed exactly for this.
> All the best.
> Il 20/04/20 06:03, Phil Wyatt ha scritto:
>> Hi Tony,
>> A lot of styling depends on the attributes of the layer so you can
>> really only pass around QML files for common layers. I have some to
>> match the Tasmanian LIST system common use layers (roads, hydrology etc)
>> https://listdata.thelist.tas.gov.au/opendata/
>> Are you specifically after some to match common NZ data downloads? I did
>> some styles a while ago for a project on the Auckland Islands using the
>> 150K topo data. You are welcome to those if they help at all
>> Cheers - Phil
>> *From:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Tony
>> Shepherd (FarmMaps NZ)
>> *Sent:* Monday, 20 April 2020 11:07 AM
>> *To:* qgis-user at lists.osgeo.org
>> *Subject:* [Qgis-user] Shared line-style resources etc
>> Hi All
>> Hope that averyone is getting through whatever lockdown conditions you
>> are under ok. Day 26 for us in New Zealand.
>> I’m just wondering of any known shared resources for line styles, point
>> styles, svg libraries etc? I have done some searching on the web and
>> found a few things scattered here and there but nothing really
>> substantial. I imagined with QGIS being opensource and loads of plugins
>> being shared that there may be a similar resource for styles etc.
>> Cheers
>> Tony
>> *Tony Shepherd* *|* GeoSpatial / Mapping Manager
>> Ph 027 435 6193 *|* E tony at farmmaps.nz <mailto:tony at farmmaps.nz>
>> FarmMaps NZ, 3 Kerwood Place, Gore 9740
>> FM_logo1_small (Custom)
>> ** <http://tonyshepherd8.wixsite.com/home>**
>> <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>**
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
