[Qgis-user] [QGIS-Developer] Memory Leak / Slowdown?
Matthias Kuhn
matthias at opengis.ch
Mon Apr 20 03:50:09 PDT 2020
Hi Peter,
Did you try this on a clean new profile with no plugins installed?
Bests
Matthias
On 4/20/20 11:08 AM, Drexel Peter wrote:
> Hi,
> I use a Python-Script to load all shapefiles in a directory tree one
> by one and export the sld-files.
> It works fine, but slows down incredible after ~100 files.
> So I tried the following barebone script with just the essentials
> (load shapefile, add it to the map canvas, remove it again and then
> clear the project) in a loop and I get the same behavior…
> from datetime import datetime
> for i in range(1, 1000):
> vlayer=QgsVectorLayer ("aShapeFile.shp" ,"run " + str(i) + " at " +
> datetime.now().strftime('%H:%M:%S') ,"ogr")
> QgsProject.instance().addMapLayer(vlayer)
> QgsProject.instance().removeMapLayer(vlayer.id())
> QgsProject.instance().clear()
> Same result, the Script slows down after every iteration in the loop
> AND QGIS-memory consumption goes up!
> Do I need to do some garbage cleaning / what am I doing wrong / is
> this a Memory leak?
> Thanks everybody for any hints / help!
> Peter
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200420/0170ffc4/attachment.html>
