[Qgis-user] Fwd: QGIS package error.
Sachin Kumar
surveykshak at gmail.com
Wed Apr 22 08:14:09 PDT 2020
---------- Forwarded message ---------
Date: Wed, 22 Apr 2020 at 20:41
Subject: QGIS package error.
To: <qgis-user-request at lists.osgeo.org>
I am building QGIS 3.10.5 on Windows 10 Pro. Everything is going right and
solution build successful and installed in OSGeo4W/apps/qgis-test folder.
After running first time I had run perl creatensis.pl it create a package
with name “QGIS-OSGeo4W-3.10.5-1-Setup-x86_64” which run successful.
When I copied my build files from qgis-test folder to
“..\ms-windows\osgeo4w\unpacked-x86_64\apps\qgis” and copied
“OSGeo4W/apps/qgis-test/bin/qgis.exe” to
“..\ms-windows\osgeo4w\unpacked-x86_64\bin and rename to qgis-bin”. After
that run perl creatensis.pl I get “QGIS-OSGeo4W-3.10.5-2-Setup-x86_64.exe”.
After installation I get the error.
Error loading QGIS
Oops, looks like an error loading QGIS
Details:
Could not load qgis_app.dll
Windows Error: The specified module could not be found.
Help:
Check C:\Program Files\QGIS 3.10\bin\qgis-bin.env for correct environment
paths.
[image: error.PNG]
Earlier I also get the same error hence I format my system and install
fresh window, but now again I am getting the same error.
Any help from qgis-developer in this regard.
Thanks.
Nihcas C
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200422/c2c777b3/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200422/c2c777b3/attachment.png>
