[Qgis-user] Primer about user management btw Postgis and QGIS
Saulteau Don
sault.don at gmail.com
Wed Apr 22 16:10:52 PDT 2020
Ensure that at a minimum you have,
CONNECT for the database
USAGE of the schema
SELECT for the table
SELECT, USAGE on the sequence(s) for that table
On Wed., Apr. 22, 2020, 14:08 Bill Williamson, <bill at williamson.fm> wrote:
> Hello QGIS workers,
> Could I ask if there is a guide to managing user's accessing of Postgis
> data via QGIS?
> I can successfully create and access new tables and schema as my own user
> (not postgres). Then I use PGAdmin4 to create a new user (I test the login,
> OK) and the grant wizard to give ALL to the new user, on the db, the
> schema, and for surety the table.
> But this new user cannot see the tables in QGIS (but can login and see the
> schema).
> PGAdmin4 Properties advises the privileges are in place.
> I don't see that I can readily manage user access out of DBManager in
> QGIS, or should I?
> Snip of SQL from PGAdmin;
> ALTER TABLE cadastre.bounds
> OWNER to me;
> GRANT ALL ON TABLE cadastre.bounds TO "User1";
> GRANT ALL ON TABLE cadastre.bounds TO me;
> regards
> bjw
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200422/aead17a7/attachment.html>
