[Qgis-user] documentation v 3.10 - PDF ?
karsten
karsten at terragis.net
Thu Apr 23 14:28:02 PDT 2020
Dear Alexandre,
>>> The documentation team decided to drop the PDF creation, because It was
a big overhead in the all process.
>>> The plan is to provide the HTML version in a zip package instead, but we
were not able to tackle that yet. We think the HTML package will replace the
PDF functionality, while providing another advantage. Having a local copy of
the HTML, one can set QGIS to use it as an alternative to online
documentation. That way, if you press a help button while offline, it will
redirect to you local copy. >>>
Sure I can totally understand the problem that creating those PDFs being a
big overhead ...
>From a user perspective (at least personally ) I think PDFs are so much
better/ more efficient to use :)
( for example if there are both versions available I always would use the
PDFs only )
I guess it would be still posisble to download the docs from source and
compile the PDFs from there - I might give it a try if I can find some
hours to spare ;)
Cheers
Karsten
A quinta, 23/04/2020, 19:26, karsten <karsten at terragis.net> escreveu:
Dear all,
I have looked at the nice new documentation for QGIS v. 3.10 online (HTML)
but wanted to find the PDF versions which unfortunately I could not locate
so far (last ones I found are 3.4 ).
Can someone point me to the doc PDFs ?
or are there none available (unless I would install all the docs source code
and try to compile them myself as PDF ) ?
Thanks + Cheers
Karsten
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200423/e4151c57/attachment.html>
