[Qgis-user] Raster translate to .asc format
Raymond Nijssen r.nijssen at terglobo.nl
Mon Aug 3 07:20:21 PDT 2020
Hi Les,
You can add a "create option" for your conversion:
value: 3
to round the values in your output.
QGIS uses the GDAL software for the conversions, and those options can
be found in the GDAL documentations:
https://gdal.org/drivers/raster/aaigrid.html
There's a "batch" option in the raster conversion dialog, which I have
never used (cause I would write a script) but I hope you figure out how
it works. :)
Good luck,
Raymond
On 03-08-2020 15:55, lesneilson67 at gmail.com wrote:
> For a project I’m working on I need to translate a collection of terrain
> tiles from .adf to .asc format. When I look at the source data the
> height values are at most to 3 decimal places (millimetres effectively).
> After translation to .asc format, all the height values have 17(!)
> decimal places.
> I’m assuming there’s a conversion going on, but is there a way to
> specify the output accuracy?
> Also, is it possible to batch convert a number of files, rather than
> loading and converting each one individually?
> Many thanks for any tips,
> Les Neilson
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows 10
> Qgis-user mailing list
