[Qgis-user] QGIS rendering round (circle) polygons as diamonds, and cannot find reason or cure
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Sat Aug 8 07:34:44 PDT 2020
Have you looked at your rendering options? Using feature simplification? Using the latest drivers on you video card?
Nicolas Cadieux
Ça va bien aller!
> Le 7 août 2020 à 13:26, Robert D. Bowers M.A. <n4fbz at tampabay.rr.com> a écrit :
> QGIS version 3.1.8
> I have a shapefile I'm working with, showing the locations of a number of what are called "post molds" - evidence that a post was put in the ground there at one point. I've drawn circles for each post mold, but they're all rendering (showing) as diamonds - squares rotated 45 degrees. Other shapes also are not rendering quite as smoothly as drawn (freehand).
> I cannot figure out what is causing this (the wrong shape for the circles). I can draw ellipses and they show up fine. I'm really reluctant to try to redraw any of the existing ones - there are several.
> The map itself covered an area of about 50 meters by 50 meters. The circles are all in the 2-5 decimeter range (approximate).
> Also, is it possible to re-size an existing polygon - for instance make an ellipse larger than the original?
> Thanks!
> Bob
> Qgis-user mailing list
