[Qgis-user] Migrating legacy QGIS instance
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed Aug 12 09:59:45 PDT 2020
QPackage would help. "Qpackage is a tool to save both your QGIS project
and data contained in the project to a new directory."
Nicolas
On 2020-08-11 1:34 p.m., Walt Ludwick wrote:
> So the plot thickens! In focusing so intently on the problem of .shp
> file conversion, i've been a bit careless in my consideration of
> Projects and their related files, but -though some of these projects
> are history that we can afford to forget- some of them will need to be
> included in this system migration, in fact.
> SO: I'll need to do some triage on these projects... And then if there
> be any "project packager plugin" that might facilitate the bundling
> and migration of those selected projects, i'd love to give such a
> try. Any such plugin(s) that you could recommend?
> On Tue, Aug 11, 2020 at 2:26 PM Nicolas Cadieux
> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>> wrote:
> Hi,
> People are suggesting that ogr2ogr would work. That will work with
> data but NOT with the QGIS projects. QGIS projects calls various
> data files in various directories, if you change the name of a
> file, the file type, the file directory structure, the project
> files will indicate that x number of files cannot be found... The
> project file contains all the Published maps.
> While most vector data file will be easy to find because of known
> formats, it will be harder to travers the hard drive for the
> raster data as formats are similar (like tiff, jpg...) If vector
> data is stored in .csv or .txt... you will have the same trouble
> identifying just the spatial data from the rest.
> I hope your user had structure and method in his folders. (Method
> to the madness....)
> One way could be to scan for the project file and see which ones
> are important and still open on the old machine. Then, you could
> look for a project packager plugin that will save all the needed
> file in a single directory. That will unfortunately take lots of
> manual work and lead to file duplications but at least, you will
> save the project files that contain a lot of work. I know of no
> other way to save the project file except to make an exact copy of
> the hard drive. I usually, at the very least, make a copy of the
> hard drive as backup in case the user comes begging two years down
> the line for a very special project file he can’t find in the new
> system...
> If all you want is the data, I agree that geopackage and tiff
> seems like a good options.
> Good luck!
> Nicolas Cadieux
> Ça va bien aller!
>> Le 11 août 2020 à 06:24, Walt Ludwick <walt at valedalama.net
>> <mailto:walt at valedalama.net>> a écrit :
>> I've inherited a legacy GIS, built up over some years in versions
>> 2.x, that i'm now responsible to maintain. Being an almost
>> complete n00b (did take a short course in QGIS a good few years
>> ago, but still..), i could really use some advice about migration.
>> i've created a new QGIS instance in version 3.14, into which i am
>> trying to bring all useful content from our old system: oodles of
>> shapefiles, essentially, plus all those other files (each .shp
>> file appears to bring with it a set of.shx, .dbf, .prj, qpj
>> files, plus a .cpg file for each layer, it seems). This is a
>> significant dataset- 14gb, >1000 files -and that is just base
>> data, not counting Projects built on this data or Layouts used
>> for presenting these projects in various ways. Some of this is
>> cruft that i can happily do without, but still: i've got a lot
>> of porting-over to do, without a clear idea of how best to do it.
>> The one thing i'm clear about is: i want it all in a
>> non-proprietary database (i.e. no more mess of .shp and related
>> files) that is above all quick & easy to navigate & manage. It is
>> a single-user system at this point, but i do aim to open it up to
>> colleagues (off-LAN, i.e. via Internet) as soon as i've developed
>> simple apps for them to use. No idea how long it'll take me to
>> get there, so...
>> Big question at this point is: What should be the new storage
>> format for all this data? Having read a few related opinions on
>> StackOverflow, i get the sense that GeoPackage will probably make
>> for easiest migration (per this encouraging article
>> <https://medium.com/@GispoFinland/learn-spatial-sql-and-master-geopackage-with-qgis-3-16b1e17f0291>,
>> it's a simple matter of drag&drop -simple if you have just a few,
>> i guess! [1]), and can easily support my needs in the short term,
>> but then i wonder: How will i manage migration to PostGIS when i
>> eventually put this system online with different users/ roles
>> enabled?
>> [1] Given that i need to pull in some hundreds of .shp files that
>> are stored in a tree of many folders & subfolders, i also wonder:
>> is there a simple way that i can ask QGIS to traverse a certain
>> directory, pull in all the .shp files -each as its own .gpkg
>> layer, i suppose?
>> Any advice about managing this migration would be much appreciated!
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200812/04de8baf/attachment.html>
