[Qgis-user] QGIS Plugins do not work (Post install fail)
Alex Rojas
a.rojas8907 at gmail.com
Sun Aug 16 08:26:23 PDT 2020
Hi all,
After installing QGIS through OSGEO4w, I received a message about a post
install fail. The report shows that many different .bat files failed to
run. Here is just one example from the install report (from file location
OSGeo4W64/var/log/setup.log):
*2020/08/11 18:37:25 running: cmd.exe /c
"C:\OSGeo4W64\etc\postinstall\qgis-grass-plugin7.bat"2020/08/11 18:37:26
abnormal exit: exit code=1*
I am unable to use grass, or any other plugins (like LAStools). I went
through the process of manually uninstalling qgis (osgeo) and removing any
folders and files. After re-installing, I still receive the same post
install errors. I am installing QGIS version 3.14, but even installing the
stable release (3.10) returns the same error. I also went through the
advanced settings, and made sure that the GRASS location was correct (under
the processing >> configuration setting).
Any suggestions to repair this issue would be very much appreciated.
Thanks!
Regards,
Alex
*Alejandro Rojas*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200816/597ecedf/attachment.html>
