[Qgis-user] QGIS Plugins do not work (Post install fail)
Alex Rojas a.rojas8907 at gmail.com
Tue Aug 18 20:53:08 PDT 2020
Also, LAS tools does not function properly. So it seems as if it is all the
plugins which do it have proper access. I also receive a message when
trying to run some of the plugins that mentions “Concurrent map locking.” I
will forward a screen shot of the messages.
On Sun, Aug 16, 2020 at 11:26 AM Alex Rojas <a.rojas8907 at gmail.com> wrote:
> Hi all,
> After installing QGIS through OSGEO4w, I received a message about a post
> install fail. The report shows that many different .bat files failed to
> run. Here is just one example from the install report (from file location
> OSGeo4W64/var/log/setup.log):
> *2020/08/11 18:37:25 running: cmd.exe /c
> "C:\OSGeo4W64\etc\postinstall\qgis-grass-plugin7.bat"2020/08/11 18:37:26
> abnormal exit: exit code=1*
> I am unable to use grass, or any other plugins (like LAStools). I went
> through the process of manually uninstalling qgis (osgeo) and removing any
> folders and files. After re-installing, I still receive the same post
> install errors. I am installing QGIS version 3.14, but even installing the
> stable release (3.10) returns the same error. I also went through the
> advanced settings, and made sure that the GRASS location was correct (under
> the processing >> configuration setting).
> Any suggestions to repair this issue would be very much appreciated.
> Thanks!
> Regards,
> Alex
> *Alejandro Rojas*
*Alejandro Rojas*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200818/6c549920/attachment.html>
