[Qgis-user] Field Calculator Expression
David Greenewalt dlg at sover.net
Mon Aug 17 17:28:03 PDT 2020
You could try a "CASE" expression:
expression CASE
CASEWHEN conditionTHEN result[ …n ][ ELSE result]END
[ ] marks optional components
Arguments
WHEN condition- The condition expression to evaluate.
THEN result- If conditionevaluates to True then resultis evaluated and
returned.
ELSE result- If none of the above conditions evaluated to True then
resultis evaluated and returned.
Example
CASEWHEN "ID" = 1 THEN 'Yellow'
WHEN "ID" = 2 THEN 'Green'END
Hope this helps,
David
On 8/17/2020 7:20 PM, krishna Ayyala wrote:
> I have the following attribute table with two fields ID and ID2
> What expression can I use within the field calculator so that, I can
> fill the values for ID2 as below?
> ID 	ID2
> 1 	Yellow
> 2 	Green
> 3 	White
> 4 	Blue
> 5 	Orange
> 6 	Brown
> 7 	Light Blue
> 8 	Light Yellow
> 9 	Light Green
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200817/ac1ce6a4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200817/ac1ce6a4/attachment-0001.png>
