[Qgis-user] Qgis Server working but not logging
SkynetSau
simone.didomenico at sautechgroup.com
Thu Aug 27 04:20:18 PDT 2020
I've an issue with Qgis Server.
above service is not writing any log
My Configuration ==========================
O.S.: Ubuntu 18.04.4 LTS
Qgis Server: 3.10.8+28bionic
web server: nginix 1.14.0-0ubuntu1.7
modalità fcgi: spawn-fcgi
Web Client: Lizmap ver. 3.3.9
Nginix Configuration ============================== [...]
location /qgisserver {
gzip off;
include fastcgi_params;
fastcgi_param QGIS_SERVER_LOG_FILE /var/log/qgis/qgis-server.log;
fastcgi_param QGIS_SERVER_LOG_LEVEL 0;
fastcgi_param QGIS_DEBUG 1;
fastcgi_pass unix:/tmp/qgisserver.socket;
added init script with systemd for fastcgi service on O.S. startup
(/lib/systemd/system/aqp-spawn-fcgi.service)
Service configuration ===============================
[Unit]
Description=FastCGI spawner for Qgis Server After=syslog.target
[Service]
Type=forking
PIDFile=/var/run/%p.pid
SyslogIdentifier=%p
Environment=WORKERS=1
EnvironmentFile=-/etc/default/%p
ExecStart=/usr/bin/spawn-fcgi \
-F ${WORKERS} \
-d / \
-u www-data \
-g www-data \
-s /tmp/qgisserver.socket \
-P /var/run/%p.pid \
-- /usr/lib/cgi-bin/qgis_mapserv.fcgi
Restart=on-failure
RestartSec=5
[Install]
WantedBy=multi-user.target
added script for enviroenment variables in /etc/profile.d/qgis-server.sh
export QGIS_DEBUG=1
export QGIS_SERVER_LOG_FILE="/var/log/qgis/qgis-server.log"
export QGIS_SERVER_LOG_LEVEL=0
typing "printenv" variables are correctly setted and server works (tested
with Lizmap and directly by typing urls of WMS external services)
Problem is only Qgis-Server log writing. I tryed also to create log file
manually and giving it 777 chmod attribute, but is always empty.
Can you help me?
Thank You.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
