[Qgis-user] layers not displayed in the layer window
Yoann QUENACH DE QUIVILLIC
yquenach at itlink.fr
Fri Aug 28 06:18:22 PDT 2020
Oh you're right, my mistake. Here is a slightly modified version of the
function that relies on the QgsLayerTree instead of the QgsCanvas. This one
won't remove layers that are only unchecked in the layer tree.
def remove_odd_layers():
project = QgsProject.instance()
project_layers = project.mapLayers().values()
tree_layers = [l.layer() for l in project.layerTreeRoot().findLayers()]
for layer in project_layers:
if layer not in tree_layers:
project.removeMapLayer(layer)
Regards,
Le jeu. 27 août 2020 à 22:03, Jens Beutmann <beutmann at arcor.de> a écrit :
> That seems to be working. Thanx a lot, Yoann!!!
> Before running the function, you have to switch on in the layer dialog all
> the layers you want to keep, because otherwise the function kills all
> layers that are not visible. But after doing that, I got the result I
> wanted.
> That helped me a lot!
> Am 27.08.2020 um 11:44 schrieb Yoann QUENACH DE QUIVILLIC:
> I had the exact same problem some time ago. The layers are present in the
> QgsProject, but not added to the QgsCanvas, so they don't appear in the
> Layer Panel but the entry is there in the Layer Styling Panel.
> You can use PyQGIS to solve it
> Here is a simple function that iters over the layers in the project, and
> removes the layers not present in the canvas:
> for layer in QgsProject.instance().mapLayers().values():
> if layer not in iface.mapCanvas().layers():
> QgsProject.instance().removeMapLayer(layer)
> remove_odd_layers ()
> Le dim. 23 août 2020 à 13:03, Jens Beutmann <beutmann at arcor.de> a écrit :
>> I got a problem with layers that are displayed in the layer design
>> dialog ("Layergestaltung" in German) but not in the layer window itself.
>> I would like to delete these layers but this is not possible. I opened
>> the project in QGIS 2.18 and in 3.10 and it happens in both versions.
>> Can anybody help?
>> Diese E-Mail wurde von Avast Antivirus-Software auf Viren geprüft.
>> https://www.avast.com/antivirus
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> <https://www.itlink.fr/>
> Yoann Quenach de Quivillic
> Ingénieur d'étude
> www.itlink.fr
> [image: Avast logo] <https://www.avast.com/antivirus>
> www.avast.com <https://www.avast.com/antivirus>
> <#m_6622802105708209006_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Ingénieur d'étude
www.itlink.fr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200828/496a65ac/attachment-0001.html>
