[Qgis-user] Live Mapping with QGIS on Toughbook
Nicolas Cadieux njacadieux.gitlab at gmail.com
Fri Aug 28 07:31:21 PDT 2020
Daniel Green from Québec?
I would start by testing in a wide open field.  Is the problem with the GPS in the laptop or with the connection with QGIS?  If it’s the later, explain what you are doing and what versions of QGIS using.  If you only get a position with the wifi, maybe you don’t have an actual GPS chip.  Look at the computer specs.  Some tablettes (iPods also) and rare phone only use wifi for positioning and do not use an actual GPS chip.  Make sure you are not in airplane mode with antenna’s turned off.
Nicolas Cadieux
Ça va bien aller!
> Le 28 août 2020 à 03:49, Daniel Greene <dannyjamesgreene at gmail.com> a écrit :
> I have been trying to use QGIS for live mapping on my Panasonic Toughbook Cf19 MK7 but I cannot get the GPS to connect when in the field. The software on the Toughbook shows it is picking up satellites so I am confident it isn’t the hardware. When I try to connect it occasionally picks up my location if I have wi-fi but without it never does.
> Any ideas what might be going wrong?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200828/103f0e9b/attachment.html>
