[Qgis-user] Live Mapping with QGIS on Toughbook
Willey, John Willey_John at co.sandusky.oh.us
Fri Aug 28 07:38:49 PDT 2020
Some more information might be needed. Is it possible your QGIS data resides in a server and not on your local machine? Perhaps the Toughbook knows where it is, but can't display the underlying map layers because it can't connect to the server? That would also explain why it works when you are in wifi service.
John
John Willey
Executive Director
Sandusky County Regional Planning Commission
2511 Countryside Drive, Suite C
Fremont, OH 43420
(419)334-6227
From: Qgis-user [qgis-user-bounces at lists.osgeo.org] on behalf of Nicolas Cadieux [njacadieux.gitlab at gmail.com]
Sent: Friday, August 28, 2020 10:31 AM
To: Daniel Greene
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Live Mapping with QGIS on Toughbook
This message has originated from an External Source. Please use proper judgment and caution when opening attachments, clicking links, or responding to this email.
Daniel Green from Québec?
I would start by testing in a wide open field.  Is the problem with the GPS in the laptop or with the connection with QGIS?  If it’s the later, explain what you are doing and what versions of QGIS using.  If you only get a position with the wifi, maybe you don’t have an actual GPS chip.  Look at the computer specs.  Some tablettes (iPods also) and rare phone only use wifi for positioning and do not use an actual GPS chip.  Make sure you are not in airplane mode with antenna’s turned off.
Nicolas Cadieux
Ça va bien aller!
Le 28 août 2020 à 03:49, Daniel Greene <dannyjamesgreene at gmail.com> a écrit :
I have been trying to use QGIS for live mapping on my Panasonic Toughbook Cf19 MK7 but I cannot get the GPS to connect when in the field. The software on the Toughbook shows it is picking up satellites so I am confident it isn’t the hardware. When I try to connect it occasionally picks up my location if I have wi-fi but without it never does.
Any ideas what might be going wrong?
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fqgis-user&c=E,1,ARlyMAoKexUsNmidgrWQCJTOZTMFcPY7mFw3sZBO1UxYh5xSRC-Dmup8fK7ljm_ZKiRekYXrflrWCsQvDwG1dmaptx4Jc1A0gyEcYv2Sg5xc28xgwQ,,&typo=1>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fqgis-user&c=E,1,GRTbC0ZPyjglWsA0lHVOqYz8C6lM2QdZrifLWsINL6a_ZsNP1UT-S4e5-qjdXHgmh-prJUcCGwUScO4eXVN831SP5FgQpZRz2ra4AuvcO5MO32GNLpdcxBm8&typo=1>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200828/8d7fb286/attachment.html>
