[Qgis-user] Live Mapping with QGIS on Toughbook
Daniel Greene
dannyjamesgreene at gmail.com
Sun Aug 30 23:28:27 PDT 2020
Nicolas, the Toughbook definitely has a GPS as i can test the connection
using the GPS software - and i have tried it in various places.
John, i have copied the project and files on to the desktop with the same
results. i have also tried it without any data to see if it can pick my
position up whilst using only a basemap but still no luck.
On Fri, Aug 28, 2020 at 10:40 PM Willey, John <Willey_John at co.sandusky.oh.us>
wrote:
> Some more information might be needed. Is it possible your QGIS data
> resides in a server and not on your local machine? Perhaps the Toughbook
> knows where it is, but can't display the underlying map layers because it
> can't connect to the server? That would also explain why it works when you
> are in wifi service.
> John
> John Willey
> Executive Director
> Sandusky County Regional Planning Commission
> 2511 Countryside Drive, Suite C
> Fremont, OH 43420
> (419)334-6227
> *From:* Qgis-user [qgis-user-bounces at lists.osgeo.org] on behalf of
> Nicolas Cadieux [njacadieux.gitlab at gmail.com]
> *Sent:* Friday, August 28, 2020 10:31 AM
> *To:* Daniel Greene
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Live Mapping with QGIS on Toughbook
> This message has originated from an *External Source*. Please use proper
> judgment and caution when opening attachments, clicking links, or
> responding to this email.
> Daniel Green from Québec?
> I would start by testing in a wide open field. Is the problem with the
> GPS in the laptop or with the connection with QGIS? If it’s the later,
> explain what you are doing and what versions of QGIS using. If you only
> get a position with the wifi, maybe you don’t have an actual GPS chip.
> Look at the computer specs. Some tablettes (iPods also) and rare phone
> only use wifi for positioning and do not use an actual GPS chip. Make sure
> you are not in airplane mode with antenna’s turned off.
> Nicolas Cadieux
> Ça va bien aller!
> Le 28 août 2020 à 03:49, Daniel Greene <dannyjamesgreene at gmail.com> a
> écrit :
> I have been trying to use QGIS for live mapping on my Panasonic Toughbook
> Cf19 MK7 but I cannot get the GPS to connect when in the field. The
> software on the Toughbook shows it is picking up satellites so I am
> confident it isn’t the hardware. When I try to connect it occasionally
> picks up my location if I have wi-fi but without it never does.
> Any ideas what might be going wrong?
> Qgis-user mailing list
> <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fqgis-user&c=E,1,ARlyMAoKexUsNmidgrWQCJTOZTMFcPY7mFw3sZBO1UxYh5xSRC-Dmup8fK7ljm_ZKiRekYXrflrWCsQvDwG1dmaptx4Jc1A0gyEcYv2Sg5xc28xgwQ,,&typo=1>
> <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fqgis-user&c=E,1,GRTbC0ZPyjglWsA0lHVOqYz8C6lM2QdZrifLWsINL6a_ZsNP1UT-S4e5-qjdXHgmh-prJUcCGwUScO4eXVN831SP5FgQpZRz2ra4AuvcO5MO32GNLpdcxBm8&typo=1>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200831/94ffd0a8/attachment.html>
