[Qgis-user] QGIS 3.xx not starting
    K R Mayani
    krmayani.procivil at gmail.com
    Tue Dec  8 19:44:26 PST 2020
Thanks, I'll check them out.
On Tue, Dec 8, 2020, 7:32 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> Just a bunch of ideas...
> Did you have a working version before or is this a first time QGIS
> installation?  You have 2 choices of installers on Windows, I would try
> with the second installer after removing the first version.  Reboot the
> computer after the installation.  Try Disabling your antivirus or adware
> software you could have when installing or starting QGIS, make sure your
> Windows and drivers are up to date.  Do you have a second version of Python
> on your computer, or a software like ESRI that as it’s own version of
> Python? Perhaps there is a conflict between your QGIS python and the
> default python distribution?  If this is not a new install, would you have
> a problématique python plugin  in the plugin directory? Perhaps try
> removing those...  Would you have weird character in your user directory
> like spaces or accents like “é”?
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 8 déc. 2020 à 07:07, K R Mayani <krmayani.procivil at gmail.com> a écrit :
> Hi,
> I am using QGIS 3.14.1 on my Laptop. I am having trouble with the software
> about its starting. After setting up python screen, it does not starts. I
> have also tried "run as administrator" but still the problem persists. With
> v3.10 and v3.14.1, the same problem is there. I have installed software
> again with "Run as Administrator" but the issue is not solved.
> .NET 4.8 already installed.
> osbuild: 19042.630
> OS: Windows 10, home
> Processor:AMDRyzen 5 3550H with Radeon Vega Mobile Gfx 2.10 GHz
> RAM: 8.00 GB
> crash: https://pastebin.com/5Tk75LTu
> Which version should support my system rig?
> Please help me with my trouble. Or suggest to me the steps.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201209/fdcd6ea4/attachment.html>
