[Qgis-user] QGIS 3.xx not starting
    K R Mayani
    krmayani.procivil at gmail.com
    Sun Dec 20 20:11:12 PST 2020
As one suggestion came from other source, I have tried opening QGIS with
firewall off. So I tried to add .exes of python, qgis ltr, qgis in allowed
program in QuickHeal, as its installed and managed firewall, but did not
start.
So that strike me another idea. And I started the program in safe boot mode
with network  in windows 10. Surprisingly the program ran normally without
crashing.
So can anyone give me any idea, what went wrong in normal boot mode?
Because in safe boot, OS does not allow to connect through wifi and I, had
to, mostly work with wifi.
On Tue, Dec 8, 2020, 7:32 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> Just a bunch of ideas...
> Did you have a working version before or is this a first time QGIS
> installation?  You have 2 choices of installers on Windows, I would try
> with the second installer after removing the first version.  Reboot the
> computer after the installation.  Try Disabling your antivirus or adware
> software you could have when installing or starting QGIS, make sure your
> Windows and drivers are up to date.  Do you have a second version of Python
> on your computer, or a software like ESRI that as it’s own version of
> Python? Perhaps there is a conflict between your QGIS python and the
> default python distribution?  If this is not a new install, would you have
> a problématique python plugin  in the plugin directory? Perhaps try
> removing those...  Would you have weird character in your user directory
> like spaces or accents like “é”?
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 8 déc. 2020 à 07:07, K R Mayani <krmayani.procivil at gmail.com> a écrit :
> Hi,
> I am using QGIS 3.14.1 on my Laptop. I am having trouble with the software
> about its starting. After setting up python screen, it does not starts. I
> have also tried "run as administrator" but still the problem persists. With
> v3.10 and v3.14.1, the same problem is there. I have installed software
> again with "Run as Administrator" but the issue is not solved.
> .NET 4.8 already installed.
> osbuild: 19042.630
> OS: Windows 10, home
> Processor:AMDRyzen 5 3550H with Radeon Vega Mobile Gfx 2.10 GHz
> RAM: 8.00 GB
> crash: https://pastebin.com/5Tk75LTu
> Which version should support my system rig?
> Please help me with my trouble. Or suggest to me the steps.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201221/fabc443d/attachment.html>
