[Qgis-user] Error of import qgis.core in PyCharme or PyScripter
Marc Yeranosyan marc.yeranosyan at gmail.com
Wed Dec 16 02:45:33 PST 2020
Re,
I reinstalled qgis to C:\Qgis...  and did all it says in your "url" but
unfortunately the error still persists. He can't find DLLs.
Marc
Le mer. 16 déc. 2020 à 11:00, Marc Yeranosyan <marc.yeranosyan at gmail.com> a
écrit :
> Hi Richard,
> Thanks for quick reply.
> You are right, I forget the python doesn't like spaces. Thanks for url, I
> will try it.
> Marc
> Le mer. 16 déc. 2020 à 10:50, Richard Duivenvoorde <rdmailings at duif.net>
> a écrit :
>> Hi Marc,
>> Did you use
>> https://qtibia.com/how-to-setup-pycharm-for-qgis-development-under-linux-and-windows/
>> to try out?
>> Another, is it possible that the space(s) in you path's maybe create
>> havoc?
>> In my java-time I always installed everything in 'programs' instead of
>> 'Program Files', just because a lot of command line tools do not like that
>> space...
>> Regards,
>> On 12/16/20 10:25 AM, Marc Yeranosyan wrote:
>> > Hi liste,
>> > I always had a problem with the integration of PyQgis libraries in
>> PyScripter et PyCharme.
>> > My lunch *PyCharme.bat* file to execute is:
>> > @echo off
>> > call "C:\Program Files\QGIS 3.16"\bin\o4w_env.bat
>> > call "C:\Program Files\QGIS 3.16"\apps\grass\grass78\etc\env.bat
>> > @echo off
>> > path %PATH%;C:\Program Files\QGIS 3.16\apps\qgis\bin
>> > path %PATH%;C:\Program Files\QGIS 3.16\apps\grass\grass78\lib
>> > path %PATH%;C:\Program Files\QGIS 3.16\apps\Qt5\bin
>> > path %PATH%;C:\Program Files\QGIS 3.16\apps\Python37\Scripts
>> > set PYTHONPATH=%PYTHONPATH%;C:\Program Files\QGIS 3.16\apps\qgis\python
>> 3.16\apps\Python37\lib\site-packages
>> > set QGIS_PREFIX_PATH=C:\Program Files\QGIS 3.16\apps\qgis
>> > set PYTHONHOME=C:\Program Files\QGIS 3.16\apps\Python37
>> > set PATH C:\Program Files\JetBrains\PyCharm Community Edition
>> 2020.3\bin;%PATH%
>> > start "PyCharm aware of Quantum GIS" /B "C:\Program
>> Files\JetBrains\PyCharm Community Edition 2020.3\bin\pycharm64.exe"%*
>> > But I have the same error while calling qgis.core or qgis._core. The
>> image is below.
>> > /Python 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914 64
>> bit (AMD64)] on win32
>> > import qgis
>> > import qgis._core
>> > Traceback (most recent call last):
>> >   File "<input>", line 1, in <module>
>> >   File "C:\Program Files\JetBrains\PyCharm Community Edition
>> 2020.3\plugins\python-ce\helpers\pydev\_pydev_bundle\pydev_import_hook.py",
>> line 21, in do_import
>> >     module = self._system_import(name, *args, **kwargs)
>> > ImportError: DLL load failed: La procédure spécifiée est introuvable.
>> > import qgis.core
>> >   File "C:\Program Files\QGIS
>> 3.16\apps\qgis\python\qgis\core\__init__.py", line 25, in <module>
>> >     from qgis._core import *
>> > ImportError: DLL load failed: La procédure spécifiée est introuvable./
>> > PyCharm et PyScripter has the same results outputs.
>> > Could it be the reason for using *Windows 10 Pro* in place of *Windows
>> Famillie*?
>> > Thank you in advance
>> > Marc
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201216/11308ed5/attachment-0001.html>
