[Qgis-user] Error of import qgis.core in PyCharme or PyScripter
Marc Yeranosyan marc.yeranosyan at gmail.com
Wed Dec 23 06:11:10 PST 2020
I found the solution. This is a Windows problem. I just uninstalled
Redistributables and replaced them by Universal 2019 VCx64. And now
PyCharme (and PyScripter) can find and import qgis.core...
Regards
Le mer. 16 déc. 2020 à 11:45, Marc Yeranosyan <marc.yeranosyan at gmail.com> a
écrit :
> Re,
> I reinstalled qgis to C:\Qgis...  and did all it says in your "url" but
> unfortunately the error still persists. He can't find DLLs.
> Marc
> Le mer. 16 déc. 2020 à 11:00, Marc Yeranosyan <marc.yeranosyan at gmail.com>
> a écrit :
>> Hi Richard,
>> Thanks for quick reply.
>> You are right, I forget the python doesn't like spaces. Thanks for url, I
>> will try it.
>> Marc
>> Le mer. 16 déc. 2020 à 10:50, Richard Duivenvoorde <rdmailings at duif.net>
>> a écrit :
>>> Hi Marc,
>>> Did you use
>>> https://qtibia.com/how-to-setup-pycharm-for-qgis-development-under-linux-and-windows/
>>> to try out?
>>> Another, is it possible that the space(s) in you path's maybe create
>>> havoc?
>>> In my java-time I always installed everything in 'programs' instead of
>>> 'Program Files', just because a lot of command line tools do not like that
>>> space...
>>> Regards,
>>> On 12/16/20 10:25 AM, Marc Yeranosyan wrote:
>>> > Hi liste,
>>> > I always had a problem with the integration of PyQgis libraries in
>>> PyScripter et PyCharme.
>>> > My lunch *PyCharme.bat* file to execute is:
>>> > @echo off
>>> > call "C:\Program Files\QGIS 3.16"\bin\o4w_env.bat
>>> > call "C:\Program Files\QGIS 3.16"\apps\grass\grass78\etc\env.bat
>>> > @echo off
>>> > path %PATH%;C:\Program Files\QGIS 3.16\apps\qgis\bin
>>> > path %PATH%;C:\Program Files\QGIS 3.16\apps\grass\grass78\lib
>>> > path %PATH%;C:\Program Files\QGIS 3.16\apps\Qt5\bin
>>> > path %PATH%;C:\Program Files\QGIS 3.16\apps\Python37\Scripts
>>> > set PYTHONPATH=%PYTHONPATH%;C:\Program Files\QGIS 3.16\apps\qgis\python
>>> 3.16\apps\Python37\lib\site-packages
>>> > set QGIS_PREFIX_PATH=C:\Program Files\QGIS 3.16\apps\qgis
>>> > set PYTHONHOME=C:\Program Files\QGIS 3.16\apps\Python37
>>> > set PATH C:\Program Files\JetBrains\PyCharm Community Edition
>>> 2020.3\bin;%PATH%
>>> > start "PyCharm aware of Quantum GIS" /B "C:\Program
>>> Files\JetBrains\PyCharm Community Edition 2020.3\bin\pycharm64.exe"%*
>>> > But I have the same error while calling qgis.core or qgis._core. The
>>> image is below.
>>> > /Python 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914
>>> 64 bit (AMD64)] on win32
>>> > import qgis
>>> > import qgis._core
>>> > Traceback (most recent call last):
>>> >   File "<input>", line 1, in <module>
>>> >   File "C:\Program Files\JetBrains\PyCharm Community Edition
>>> 2020.3\plugins\python-ce\helpers\pydev\_pydev_bundle\pydev_import_hook.py",
>>> line 21, in do_import
>>> >     module = self._system_import(name, *args, **kwargs)
>>> > ImportError: DLL load failed: La procédure spécifiée est introuvable.
>>> > import qgis.core
>>> >   File "C:\Program Files\QGIS
>>> 3.16\apps\qgis\python\qgis\core\__init__.py", line 25, in <module>
>>> >     from qgis._core import *
>>> > ImportError: DLL load failed: La procédure spécifiée est introuvable./
>>> > PyCharm et PyScripter has the same results outputs.
>>> > Could it be the reason for using *Windows 10 Pro* in place of *Windows
>>> Famillie*?
>>> > Thank you in advance
>>> > Marc
>>> > _______________________________________________
>>> > Qgis-user mailing list
>>> > Qgis-user at lists.osgeo.org
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201223/693e0a8d/attachment.html>
