[Qgis-user] QGIS running on RDS server
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Feb 10 06:01:48 PST 2020
I believe some calculations are, optionally, being ran using OpenCL if it’s available. You might want to keep than in mind. Rendering has been accelerated using parallel processing on the cpu for a while now so using more than one cpu would be recommended. I would allocate 8 to 16 GB of ram for large projects. Personally, I would not run it in a virtual environment, specially if the files are not local. You could probably get away with it for small projects.
Nicolas Cadieux
>> Le 9 févr. 2020 à 21:48, Sandra Menares <smenares at correct.com.au> a écrit :
> Hi Community,
> We are planning to install QGIS on a Remote Desktop Server using Windows 2016 server with Hyper-V.
> 1. Does QGIS runs in a virtualized environment?
> 2. Does the virtual host needs special graphics card, like ArcGIS does? Like a NVDIA GRID card to pass through GPUs to the VM? https://pro.arcgis.com/en/pro-app/get-started/on-premises-overview.htm
> 3. What would be the minimum hardware requirements? CPU, RAM?
> Thanks so much in advanced.
> Kind Regards,
> Sandra Menares | Project Engineer
> Correct Solutions
> Unit 3, 7 Anella Ave, Castle Hill NSW 2154
> Ph: +61 2 8831 8200 | Fax: +61 2 8831 8299
> Website | Correct IT Blog | Newsletter | LinkedIn
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200210/a8df1c02/attachment.html>
